1999 e300td code 0560
Old Jun 27, 2023 | 10:50 PM
Om606marsh's Avatar
1999 E300TD
Well this is my first time joining a forum and also my first time owning a Mercedes… ouch lol. I recently picked up this 1999 E300TD and after about 800miles the car randomly wouldn’t start. This problem has become common now but still intermittent. It has thrown code p0560 for low system voltage since the problem started. The key works fine (unlocks the car, unlocks the steering lock, turns and illuminates the dash, runs the glow plugs) but after the glow plugs run and you turn the key to crank, nothing. No click, no voltage drop, doesn’t try to turn over at all. I have figured out that when this problem happens, I can unhook the ground to the battery for about 30 seconds and hook it back up then the car will fire up no problem but the check engine light is consistent. Battery is brand new and I just installed a new k40 board with no change. Also recently installed a Sean Traecy stage 2 ECU so the ECU is out of the equation as well. I really appreciate any help.
Old Jun 27, 2023 | 10:57 PM
Om606marsh's Avatar
1999 E300TD
Old Jun 28, 2023 | 02:49 AM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
moved to W210 forum...
Old Jun 29, 2023 | 08:48 AM
Om606marsh's Avatar
1999 E300TD
Why would the ignition switch cause a low voltage code? The AC blower motor recently started to surge and the engine also stated to surge under moderate boost. Also why against the tuned ECU? It deleted the egr, immobilizer and MAF ect… also picked up a bunch of power.
