window onetouch down/up not working???
Old Nov 12, 2004 | 07:53 PM
cflanza's Avatar
C43
I changed my battery after it crapped out on me. After installation of the new battery, i cant activate the onetouch down/up for the window. And the moonroof is acting wierd, it stops just about every 4 inches even with my finger holding on to the switch.
Any ideas on what to do before I go to the stealer?
Old Nov 12, 2004 | 09:23 PM
sosh's Avatar
2010 ML550, 2010 E350 4M, 1966 Corvette Convt C2
Try resynching both the windows and the roof. Do this by fully closing then holding the switch in the close position for about 30 seconds.
Old Nov 13, 2004 | 07:41 AM
stemags's Avatar
2014 E550 4matic,, sold 2012 E 350 4matic,,sold 2010 e350 4w,sold 2002 e320 se
I thought you accomplished synch by doing the same thing when you changed the batts. in the remote.Placing in ign. etc.??
Old Nov 13, 2004 | 03:55 PM
The Godfather's Avatar
4 wheeled car.
After I disconnect or replace my battery (same thnig lol) , the one touch doesnt work for a little while, then it comes back.
Old Nov 13, 2004 | 04:37 PM
sosh's Avatar
Believe thats to synch just the remote.
Old Nov 13, 2004 | 09:36 PM
SLAMMED_C's Avatar
1999 C230 Kompressor, 2002 E320 4matic
press each window switch up (first position, not one touch second click) and hold for 3 seconds..
press the sunroof button in the up position and hold for 3 seconds.. this should resync it.
Old Nov 23, 2004 | 09:49 AM
tj99e320's Avatar
1999 E320 - Desert Silver
Sunroof resynch
I too just replaced my battery and ran into this problem. Using your
procedures above, I was successful in resynching (new word) the windows -
thanks, but I'm not quite clear on how to do the sunroof.
What is the Up position, flip up? I tried that with no success...
actually I don't even remember what is one-touch on the sunroof.
Will it close and open with a single touch?
Thanks,
TJ
Old Nov 23, 2004 | 02:08 PM
mobinakhtar's Avatar
MY2004 E320
Angry One touch moonroof?
My 97 e420 does NOT have this feature. How come Bimmers get express open and close moonroof and we don't?
Old Nov 23, 2004 | 10:31 PM
SLAMMED_C's Avatar
Depends on the year of the MB.. the older ones didnt have express open/close sunroof at all, some of the newer ones had express open only.. then the latest models have express open and close. Just depends where you fit in.
With resyncing the sunroof, you need to hold the switch by pressing it in the foreward close position (hold for 3 seconds) this should resync it, if not try holding in pop up position for 3 seconds.
Old Nov 29, 2004 | 02:52 PM
cflanza's Avatar
C43
Talking It's working now
Thanks to all that repied. It turns out that all it needs is time. I was going to try to do all the suggestions here, when I tried the windows for the last time before doing all the suggestions, it already works fine.
Old Feb 27, 2011 | 07:36 AM
Techhead58's Avatar
E55 AMG
This simple tip solved my window problem in 3 seconds, fantastic.
Old Jan 23, 2013 | 11:51 PM
Cuddalore Kumar's Avatar
The real trick in executing the RESET operation outlined in the manual as well as what is explained in this forum is to not press the power window button too much. You can perhaps follow this procedure below. Open it enough (may be in several small increments) to provide 6 or 7 inches for the window to move up. We never do this when AUTO is functioning well, but by pressing it slightly (not all the way down) you can get the window to move up smoothly in a continuous motion. Continue the same touch and hold it till the window has completely closed and for about 10 seconds or so beyond that. That will RESET it as intended. Pressing the button hard, all the way down does not seem to do the RESET. Also, any amount of instructions may not be sufficient. Just play with it a little bit and you will get the hang of it.
Good Luck.
Old Mar 20, 2015 | 08:31 PM
E320LVR's Avatar
1998 E320, 1994 E320 Wagon, 2002 ML
Worked like a charm! Thank you SLAMMED C
