Hit the Mother of all Potholes...
Anyone else do something like this? Do you think its a bent control arm or something less??? I find out on Wedensday...wish me luck.
Keep that in mind.
...can I have a job pleeeeze???
Also, they detected a O-ring seal leak on the Tranny. So they replaced those and did a tune up to it (drain and fill, new filters, etc.) Wow! what a difference. The car shifts much more smoothly now up and down. 91K on the car.
"Hello My Name Peggy"
I must have then hit the ghost of potholes past. I found out this morning one of my rims was out of round while having new tires put on for scheduled change (7:30am thankyouverymuch I'm not a morning person).
- First concern - they told me it wasn't a hugh issue and put the rim on the rear axle.
- Second concern - they told me I could send the rim off and Mercedes would "heat it to reshape it" vs $500 est for a new one.
Comments...questions...concerns?
First concern work around for now: they didn't think of this - and I didn't either until after I left, to have them exchange the spare rim with the one I'll send off.
Second concern: do they really heat rims to reshape them at MB? And does this weaken it (metallurgy is outside my paygrade). I'm guessing they are very smart at MB and wouldn't do that to their precious wheel. I do want to get the rim fixed (or replaced), but not risk my safety for a few hundred smackers so will not make the assumption.
Rims are the standard alloy issue and original to the car as far as I know. There was no visible sign of damage and no vibration before tire/alignment this morning, even at high speeds :-) There's no telling when this happened - anytime in the last year.
You can barely see it only when you spin the tire on the axle but you had to stare straight at it (and compare to a good rim spin). Nothing eventful in the routine tire alignment or brake job today - just standard stuff. Just so happens both collided at the same scheduled visit. Oh ya...and a Schedule A - cha-ching.
Hit one last week in NJ doing 60,,,lost 10 lbs of air after 8 hours but refilled it and its fine.
Whatever it was, I hope I don't ever encounter it.
you could get a whole set of custom 16in rims for $500
Mercedes will not repair a bent rim. They just send it to a rim repair outfit.
Stop going to the dealer. If a service A cost you " cha-ching"
you paid to much.
The Cha-ching was because of all the routine work I had in 24 hrs (scheduled check up, brakes and tires). Yes Dealer Schedule As are pricey. I am lucky I found a great Italian mechanic I trust, and who does all my work at his own shop.
