W211 Amg brakes on W210
Old Jan 17, 2005 | 05:28 PM
hubert's Avatar
14'G63 AMG ,1994 Mercedes E500, 2020 Range Rover HST
I think its possible go to W203 forum a guy fited those brakes on his W203 so if W203 brakes fit our W210 the W211 AMG should fit ours W211.
Old Jan 18, 2005 | 02:04 AM
Alexbenz's Avatar
Sean's Sister--
i believe it's possible, anythings possible but you might need to custom make the hat for it to fit.........
Old Jan 18, 2005 | 02:18 AM
Whitey's Avatar
98 W210 Advantgarde
8/4 piston SL55/E55 brakes on W209 CLK500, N.B. 18" rims (member: Shine):
Old Jan 18, 2005 | 02:25 AM
Whitey's Avatar
98 W210 Advantgarde
More Info:
Shine:
**SL55 brake is standard in 14mm holes while W203/W209 is 12mm, You've to re-drill all the holes to 14 mm
The dealer spare all the converters w/pre-drilled 14mm holes as part of the package , so no bothering at all
What else I saw there, the mechanic slightly cut off the rear dust hood in order to fit the rear 330mm disc.
They did alignment after kits was bolt on.
Old Jan 18, 2005 | 02:28 AM
Alexbenz's Avatar
Sean's Sister--
damn it, i need to coyright my ideas from now on, dave remember what i was saying last night............i had this idea a long time ago............
Old Jan 18, 2005 | 02:30 AM
Whitey's Avatar
98 W210 Advantgarde
Dude, this guy did it back in 2003 (some rich kid in Taiwan apparently....obviously!)
Old Jan 18, 2005 | 02:47 AM
Alexbenz's Avatar
Sean's Sister--
ehhhh, i mean US? lol, i have no control over international waters
hahaahahaha
Old Jan 18, 2005 | 03:07 AM
Whitey's Avatar
98 W210 Advantgarde
BTW, Hubert, I think the W203 only had C32 brakes installed...that should be a direct bolt on. SL/E55 brakes have a lot more pistons, hence the C230's smaller master cylinder might have issues...not sure about the ones on your 320 which should be a heavier duty one.....
Old Jan 18, 2005 | 04:09 AM
miroj's Avatar
Considering that W210 AMG E55 brakes are probably more powerful than W211 AMG brakes it sounds like a silly idea.
Old Jan 18, 2005 | 04:02 PM
hubert's Avatar
Whitey they are the W211 e55 brakes, look
Old Jan 18, 2005 | 11:08 PM
Whitey's Avatar
98 W210 Advantgarde
Missed that one.....that makes two on this board then.
Old Jan 18, 2005 | 11:22 PM
vraa's Avatar
Those are some freakishly large brakes.
I like!
Old Jan 19, 2005 | 11:29 AM
simlow's Avatar
It would be fantastic to be able to install 8pot calipers from W211 to W210
Regards,
Simon Low
Old Jan 19, 2005 | 05:40 PM
LorinserLV2's Avatar
96´E280 6.cyl
Are the W203 amg ones "bolt on" for the W210 or do they require some modifications?
Old Jan 19, 2005 | 06:04 PM
Alexbenz's Avatar
Sean's Sister--
W203 Bolta Right On, W211 Need Some Work Done...
Old Jan 19, 2005 | 06:59 PM
miroj's Avatar
Why would somone want an inferior W203 AMG brake when the W210 AMG brake is one of the finest pieces of equipment ever developed.
This POT quest is childish .... look at the square inches of contact area.
Old Jan 19, 2005 | 09:30 PM
Whitey's Avatar
98 W210 Advantgarde
Cuz people upgrade their brakes for both performance AND looks, the W210 E55 brakes just don't fit the bill.....
Old Jan 19, 2005 | 09:32 PM
miroj's Avatar
That doesnt make sense ..... you cant appose two points with one position.
Old Jan 20, 2005 | 03:26 AM
Ben'z's Avatar
E320
Is the rotor installed correctly?
For my understanding, they should be changed to opposite side.
Old Jan 20, 2005 | 05:20 AM
96´E280 6.cyl
I bet that C32 AMG brakes are much better than my OEM brake setup LOL
And by this time my brakes are starting to vibrate THey just dont do the service heheh
Old Jan 20, 2005 | 05:44 AM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
There are no "sides" on OEM cross drilled rotors from Mercedes. They are all the same. Please search the forums for further information on this.
-s-
Old Jan 20, 2005 | 11:52 AM
Whitey's Avatar
98 W210 Advantgarde
-s-
I've been wondering if he was referring to the direction of the holes or the position of the calipers - ours are on back, whereas the 209 is in front. (i.e. trailing vs leading, push vs pull etc).......
Old Jan 20, 2005 | 01:38 PM
Ben'z's Avatar
E320
Yes, I mean the direction of the holes on the rotor.
Sorry, I don't know it doesn't matter for OEM.
Please ignore my stupid!
Old Jan 20, 2005 | 04:34 PM
scorchie's Avatar
Actually, Mercedes is the stupid one for doing that!
-s-
Old Mar 31, 2011 | 04:58 PM
bmartins's Avatar
w210 300td
Hello.
Does C32 calipers fit my W210 300td?
I want to upgrade it..
thanks
