E-Class (W211) 2003-2009
OEM Navigation Retrofit w/ pics
Rating: Thread Rating: 7 votes, 5.00 average.
Old 12-14-2010, 12:24 PM
  #301
Mackhack's Avatar
Originally Posted by Still_Waters_43
The original part#s are for a E320 (like you guys have), I'm looking for parts for a E350 (which has different part#s). And as noted previously the dealer claims they only have the kit #. So, I'm hoping to connect with someone who has done the E350.
Sent you a PM!
Old 12-14-2010, 12:29 PM
  #302
Toolman_Johnny's Avatar
2005 E320 CDI (W211)
Sorry mate. Guess I assumed that if it's a W211 (an E320 or E350), the listed part numbers would work.
One thing you can do, is find another car (like on eBay) that is the same year, model , trunk interior color, rear seat config (folding versus non folding) as yours....but HAS the Navigation option. Take this VIN number, and call your dealer. With that VIN number, they should be able to look up the parts individually.
Alternatively, you can contact mbdoctor.com, and order a kit from them...or perhaps they'll confirm the individual part numbers you need.
Cheers, TJ
Old 12-20-2010, 12:37 PM
  #303
SterlingG's Avatar
2003 e500
I'm trying to find out how to unplug the 6 disc changer so I can install the navigation comand module. The plug I can't get removed is the orange optic cable....
Old 12-20-2010, 01:03 PM
  #304
Mackhack's Avatar
There is a notch. Simply move it and unplug it. There is no navigation COMAND module. You can't put a map DVD into the COMAND.
Old 12-20-2010, 11:23 PM
  #305
SterlingG's Avatar
2003 e500
I agree but if you have the comand module with a tape deck it will never do nav...... that is what I'm trying to switch out....
I just wish someone had a pick of this "notch"
Old 12-20-2010, 11:33 PM
  #306
Mackhack's Avatar
For what? Fingernail is enough. Can't be that hard. Or ask your GF/wife
Uh, tape deck... wow that's old... time to upgrade
Old 01-31-2011, 11:36 AM
  #307
pcar928sg's Avatar
2003 e500 sport
Originally Posted by MBenzNL
I don't think he needs an eye specialist...in fact he was right...
9F08 is the colorcode for the W211 trunkpanels as of VINnumber A644805 (07/13/2004) and X170411 (08/17/2004) where as 9C53 is the colorcode for the W211 trunkpanels before thse Vin numbers...
9C53 is anthracite...9F08 is black...the 2005 W211 needs a black trunkliner...
greetingz,
Is anthracite grey? My parts guy is saying its black..... my 211 was built in early 03.....
anyone have the part number for a w211 with folding rear seats, NAV and grey trunk liner?
Old 01-31-2011, 02:30 PM
  #308
There are probably over two dozen different different part numbers (for these trunk panels). Because of all of the erroneous information in this thread, I ordered the wrong panel, and went through quite a hassle to return it.
The correct part number will depend on model year, options installed, and color. Save yourself the hassle (or ordering the wrong panel), and find a vehicle (on eBay or AutoTrader.com) with the same model year, options installed and color you need. Write down the vin number of that car, and call your dealer to get the proper part number for the trunk panel. There's still a risk in doing this....in the event that that other car had the NAV system retrofitted. But, the risk is sufficiently low...since there aren't too many people out there that have retrofitted NAV systems in their MB.
Your dealer has no way to tell you which panel (part number) will work for your car. The only way they can look it up, is by VIN number. And, at risk of stating the obvious, your VIN number won't work...since your car didn't come with Nav.
By the way, anthracite is black.
Cheers, TJ
Old 01-31-2011, 03:10 PM
  #309
Diesel Benz's Avatar
Cheers, TJ
This did not remove a lot of mistakes from the thread.
I guess you did not intend to say that anthracite and black are the same colour? Anthracite is black but 9F08 black is a different colour from 9C53 anthracite.
The dealers have good tools that allow easily to pick up the correct part for a car if they just spend some time with their tools. You probably mean that the parts guys are used to looking up parts based on the car VIN but are too simple to look up a part that is needed for a retrofit task.
Old 02-01-2011, 12:30 PM
  #310
Originally Posted by Diesel Benz
......Anthracite is black but 9F08 black is a different colour from 9C53 anthracite.
This illustrates my point exactly...more erroneous information.
The color code 9C53 is NOT Anthracite(Black), it's for Grey.
Old 02-01-2011, 01:36 PM
  #311
I might know where you conclude that. The question would be how dark grey would be black or anthracite and your definition may be different from that of MB.
See what EPC says for that colour code. The only colour options EPC gives for 211 (I only tried 211.026) are "anthracite" and "single tone black". I'm guessing the MB anthracite is light enough that you would call it grey. Fair enough but in MB spare parts terms it would be anthracite and there is no "grey" available at all.
Or are you saying EPC has been wrong all these years?
Attached Thumbnails OEM Navigation Retrofit w/ pics-9c53-anthracite.jpg
Old 02-02-2011, 09:07 AM
  #312
Anthracite is a form of coal, and is black as black can be. The MB color code named "Anthracite" is also black. In short, yes, perhaps EPC is incorrect, because the color code 9C53 is Grey in color, NOT black. I have black interior and the first trunk panel I ordered (based on info from early on in this thread) was color code 9C53. It arrived, and I was VERY disappointed to find that it was Grey....there was no mistaking it for black. I returned that panel, and ordered 9F08 Anthracite(black) instead, and that panel is Black. Is it possible that Anthracite is somehow considered Grey in color in other countries??...I don't know. But, the very definition of Anthracite would lead one to believe that any color code with the same name, would certainly be black.
Old 02-02-2011, 10:04 AM
  #313
SterlingG's Avatar
2003 e500
I took the removed panel and got the number from it.... The panel is grey and the part number ends in 9C53
Old 02-04-2011, 01:34 AM
  #314
wampa's Avatar
E500 & ML500
Yes anthracite is gray.
That's a pic I took of the following:
Trunk liner
- Rear folding seats
- No power outlet
- Color Gray
211-690-01-53-9C53
Old 02-04-2011, 07:32 AM
  #315
Oy vay!
In the end, it doesn't really seem to matter what the color code is named, does it? Color code 9C53 is Grey, and 9F08 is Black. If some MB systems, or some people want to refer to Grey as Anthractie, knock your socks off. It's still Grey. When I ordered my black panel, the parts guy told me that the color code 9F08 was referred to in his system as "Anthracite". But again...who cares what it's called. If you need a Grey panel, the part number should end with 9C53....if you need Black...the part number should end with 9F08. I'm tapping out on this one.
Old 02-04-2011, 09:41 AM
  #316
Mackhack's Avatar
Oh vay!
This is the key after how many postings about it?
Old 02-04-2011, 10:47 AM
  #317
SterlingG's Avatar
2003 e500
The irony is that when I try to order 211-690-01-53-9C53 through 3 different MB dealers all 3 say its not a valid number
Old 02-04-2011, 11:20 AM
  #318
wampa's Avatar
E500 & ML500
I ordered mine from parts.com. (I just checked and it's still available. )
It arrived in a huge box
Old 02-04-2011, 04:29 PM
  #319
Mackhack's Avatar
How comes that the black trunk liner is cheaper than the gray one???
Old 02-05-2011, 10:30 AM
  #320
The Grey pigment is made from the oily secretions of the fur from the rare Two-Toed Peruvian Tree Sloth.
Old 02-05-2011, 11:28 AM
  #321
Mackhack's Avatar
Well if that doesn't explain it hehe You're my
Old 02-05-2011, 06:06 PM
  #322
SterlingG's Avatar
2003 e500
my cost on the black one was $99 and the grey one is $176 thru the dealer... so I guess I will order it rhu the parts.com site....
Old 09-08-2011, 11:08 AM
  #323
M3Jota's Avatar
04 E500 4Matic
Hello, I am new to the board and have been doing some reading on this topic. This retrofit seems pretty easy and am probably going to tackle it in the next few months. My question is the following,Steph mentions in the first post that that "particular model has everything pre-wired, so the install would consist of installing a DVD processor in the trunk for plug and play operation.". How can I tell if my car is prewired for this? I have a 2004 E500 4Matic, with the COMAND system but no nav. Any help will be appreciated.
Old 09-08-2011, 11:23 AM
  #324
Mackhack's Avatar
If it's a US spec car it is pre-wired.
Old 09-24-2011, 03:46 AM
  #325
crazy00c230k's Avatar
2000 c230 kompressor special edition, 2012 E550 coupe (sold), 2017 C63 sedan (sold), 2018 C63S Coupe
Hello guys, I'm a long time lurker, just picked up an 04 e320 a few weeks ago and I'm planning on doing this upgrade. If I am planning on doing the "B-Pillar" MOST loop connection are there supposed to be any loose fiber cables afterwards? For the life of me I cannot find an empty fiber cable w/just a black connector. I've found the loose white one just fine. There are two black connectors, one that loops back into the trunk and another that goes through the drivers side entry panel up to the head unit (I'm assuming). There are also two other fiber cables that go from the trunk through to the front of the car but there are no visible connectors on them. Any help/insights would be greatly appreciated. Thanks in advance
You have already rated this thread Rating: Thread Rating: 7 votes, 5.00 average.
Quick Reply: OEM Navigation Retrofit w/ pics
