Car stuck in snow
As you can imagine, I was pretty stressed at the situation, especially as folks were trying to dig me out with sholvels. (I did get one small scratch on the plactic underside panel below the passenger door, you can't see it unless you're on the ground looking up)
I knew I should have gone for the 4matic!!!
Remember this also; a two wheel drive car with winter tires will outbrake a 4 wheel drive car with all-season tires. That is why you tend to see many 4 wheel/all-wheel drive vehicles in the ditch; false sense of security. It is easier to get into big trouble with all-wheel drive if you are not an experienced winter driver.
You didn't say what tires are on your car. Check tirerack.com reviews section and see what people say about the tires you have on the car for snow traction.
I am going to be driving out to Utah in about a week, and I may take a trip through California. I ordered a set of Pewag Sportmatik tire chains for $160 including shipping. I didn't buy the Rud chains Mercedes recommends because I assumed that they would cost much more. The tire chains would be messy to put on, but I liken them to relatively cheap insurance. I just did a test run putting the chains on, and it is not as easy as it appears on their website. Your car looks like it may have 17 inch rims, which I don't think will accomodate tire chains. Tire chains would be a solution for you now, but I would check with Mercedes to see what would fit.
Consider also carrying a small shovel and some sand for traction if you are travelling in snowy mountainous country. Good luck!
William
2003 E320
Thanks for the thoughtful reply. I agree that winter tires are the ticket. I am debating whether to get them this year or wait until next. I am hoping that the snow season is almost over. I do have 17 inch Pirelli 245/45...I can tell you already that they are not good on snow. I looked at Tirerack and they have some winter pirelli's that will fit. I think I'll get some new rims as well so the change out is easier. Thanks to all who posted words of hope. I washed the car up today and put in it the garage. Looks good as new! I'll post some pictures soon, when it dries out a bit and I take it out of its dry, warm resting place.
Now for the big question...which winter tire should I get? Do I have to stay with the same size 245/45?[B]
Our last snow storm my buddy who just purchased a CL55 had troubles just taking off at a light and we only had a 1" of snow on the ground. Winter tires make a such a big difference.
I have the same size on all four wheels (245's) on my stock 18" rims.
There are so many excellent tire options; I can understand the trouble you are having choosing. If you start browsing different online forums, you will see that there are fans of Nokian Hakkapelitta tires, Bridgestone Blizzak, Michelin Artic Alpin, Pirelli, Dunlop and others. Just take your time, talk with people and you will come to a decision. What helped me choose is this; were I to make the worst possible winter tire choice, that choice would be infinitely better than any all-season tire (Nokian all-season tires may be an exception).
I second what hilmar2k said. The ESP on this car works great, as long as you have winter tires if you are going to drive in winter conditions.
If you decide to go with a 16 inch rim/tire combination (225/55-16), just make sure that you have no brake clearance issues; this means that the 16 inch rims might not fit over the disc brake caliper.
I got a separate set of rims because I was able to pick them up used for not much money, and I detest the mini-spare. I do long distance driving and I do not want to be constrained by the vehicle speed and range limits of the mini-spare.
And for all you 4-matic drivers, if you have winter tires on your 4-matic, your vehicle is superior to our 2 wheel drive cars as long as you remember to exercise proper caution!
William
2003 E320
I think in the UK our snow tends to be a lot wetter with around 96% atmospheric humidity. Both of my MBs are garbage in the snow, even on a level surface. However, they are no worse than the 2 Bimmers I had previously.
I have only gotten stuck in the snow once in my 4 Matic (with these tires). I more or less high centered the car on deep snow. I was able to back out without spinning out, but there was no way to move forward. So I got out the car, turned on the driveway heat and used the snow blower for a while. Then I got the car up the driveway.
March and April are our months when the most snow falls here. It is usually really wet and heavy. This is a totally different animal to drive on. I actually prefer the snow when it is powder and very dry due to really cold temperatures. Also, driving in temperatures when it is just above or below freezing is the worst and most dangerous since you can melt the snow and turn it into ice easier. Wet snow resists movement a lot more and can cause a lot more hydroplaning. This is when the 4 Matic is really useful.
Steve
Background: My name is Amy, and I guess by the name it tells you I’m a girl. I live in Central Vermont, and went to school in Michigan so I had my share of winter driving and got stuck way too many times. I work in a rather professional office so I wear a lot of skirts and dresses. I have a 2003 Mustang with manual transmission and a 2006 Mustang with automatic transmission. On this particular night I had my 2006 Mustang, it has all season tires on it, and this was the first time in the snow with it. I had left work about 7pm, we had a 3 inch mixture of snow and ice on the roads and cars, it was still snowing lightly. Actually due to my being somewhat of an air head I had to let the car warm up about 15 minutes because I neglected to put a snow brush and ice scraper in the car. So after warming the car up, I struggled to get the car our of my parking space and out of the parking lot, and managed to make my way to the entrance ramp to the interstate, a normal 10 minute drive which this night took about 30 minutes. The entrance ramp was clogged with cars trying to make it up, so I thought that I would drive to my tennis club to burn a little time and use the ladies room because by now I had to go sooooo badly. The club is located in a part of an industrial complex, I turned onto the road leading to the club, and was not picky as to where to park which was a parallel parking space in front of the building, only to find the place closed. The area where my club is, is not widely traveled and you somewhat have to go out of your way to find it, and also in a bad area as my cell phone could not get a signal. Once back in the car I found myself stuck so badly, spinning my wheels helplessly. Not that I mind being stuck, because for me I feel sexy and helpless spinning my wheels in my Mustangs, and you often meet some real cute hunks who are more than gladly to rescue the “damsel in distress”, however I was really not going anywhere, and I was getting frantic because of my need to use the ladies room at the time rather badly by now. I think I was there for a total of two hours and must have been on a lot of ice also because I was not going anywhere, when a plow operator who plows the club parking lot came by and helped me out of my situation. I finally made it home about an hour or so later.
Question: I would like to know from you guys other than getting new tires, which might or might not of helped what a girl should keep in her car so that she was have a decent chance to getting out of a situation (if I want to) again I know there are going to be times when I might not be able to do it on my own, however I would just say like to have an 80% chance at it. I really would like a list which could be a survival kit for female drivers in the snow. Also do you think snow tires would have made any difference in this situation, or would I have been still stuck on and in the ice snow mixture?
I keep re-reading this looking for the letters "M" & "B" together.. or "w211" somewhere in those paragraphs.. but nothing! Are my eyes failing me?
Talk about off-topic!
Sorry that you got stuck, Amy, but,
!!Oh, btw, my answer to your question: snow chains!
Don't feel bad about landing here. If you don't get the info you need here try to Google the following words; Ford Mustang Forum Snow . That should give you a list of solid leads to post your question. Then you will be Unstuck, Amy!
BTW, thats a very long post, most guys will not read a long fully detailed post like that. (We're Guys, Remember?) Try to just present just the facts, to get the most answers, without getting any barbs.
You also might want to ask your local Cops what they reccomend be in your trunk because they work there & know what they would want in their GF's car.
Get a set of snow chains...and if you're ever stuck on the highway or something, don't accept offers of help from strangers. Wait until the police or a tow truck shows up.
1- Actual Snow Tires (Blizzak, etc.) mounted.
2- Factory tool kit w/ tow hook attachment.
3- Warm work gloves.
4- Tow strap.
5- Ice scraper/ snow brush.
6- Extra ice melting washer solution for trips out of town.
7- Something to stay hydrated with (water, gatorade, etc.) in case a long walk is necesarry.
8- If possible a cell phone or other communication device.
9- Golf Clubs (because you never know when the opportunity will arrise
