E-Class (W211) 2003-2009
V1 install
Old Sep 18, 2011 | 04:04 PM
  #101
Mackhack's Avatar
Originally Posted by irondad
OK... it looks like a phone plug.
I know. The plug isn't the problem. I need to know which pins are being used. That's why I would like to get a detailed picture of the connector/plug. You can email it to me.
Old Oct 20, 2011 | 01:27 PM
  #102
Mackhack's Avatar
Everyone who is interested in a cable for the Valentine 1 (V1, Valentine One) can PM me.
Old Nov 21, 2012 | 01:17 PM
  #103
scotty_b's Avatar
2005 E55 AMG
Awesome thread. I hardwired a Passport 9500ix last night in about an hour. Ran it from the rear view mirror across the headliner, down the door-side of the A-frame pillar under the dash (after removing the torque screws) and into the switched cigarette lighter. I removed the ash tray itself and I mounted the smartcord mute button in that area. It works better and you have more room without the tray (if you can do without smoking). The hardest part of the job was getting the smartcord into the ashtray area. Thanks to all who came before me!
Old Jan 27, 2013 | 11:39 AM
  #104
NCBob's Avatar
2012 C63; 2011 E350 Coupe
Hate to bring back an old subject, but I'm stumped. I drive a '12 C63 AMG sedan.
I pulled the shifter plate off the console, removed the two screws from the ash tray, but could not gain enough clearance to pull out the ash tray assembly. Need to get it all the way out for access to the cig lighter wires. Anybody have a secret they want to share?
I'm afraid to pull off the console side panels for fear of breaking them.
Is there another more easily accessible switched 12v source I can use?
Old Jan 27, 2013 | 11:50 AM
  #105
Ammi's Avatar
Varies
fuse box?
Old Jan 27, 2013 | 01:40 PM
  #106
BagMan's Avatar
E55, E320 CDI , CLA250, Jag XJ Supersport
Get v1 savvy. Plugs right into the OBD port and shuts the *** thing up also.
Old Jan 27, 2013 | 02:03 PM
  #107
Mackhack's Avatar
C-class question in an e-class forum? My aux cable might be the trick?
Old Jan 28, 2013 | 01:35 PM
  #108
NCBob's Avatar
Did a V-1 search and this thread was the most informative.
Not just any C-Class...C-63!!!
Old Jan 28, 2013 | 02:00 PM
  #109
NCBob's Avatar
Thanks Bag,
Ordered today. Been to the V-1 website and never saw this.
Appreciate the help.
Mack: Since I own a lowly C-63, I'll be sure to stay in my own playground.Bob
Old Feb 1, 2013 | 05:13 PM
  #110
NCBob's Avatar
For those that have the Valentine, the Savvy conection is the simple hookup.
Plug it into the OBD, run the wires and you're in business. It's switched. No splicing or tapping. Took me 15 minutes.
Thanks to Bag302 for the tip.
Old Feb 1, 2013 | 05:37 PM
  #111
GregMB's Avatar
The only catch is that the SAVVY requires the OBD-II port constantly.... if you want to use that port for other things (ie. Data Logging with Kiwi) you are probably going to have to disconnect the V1 to do it.
I tried using an OBD-II "splitter" to run both devices but the Kiwi doesn't like it and won't link properly.
If anyone knows of a workaround, I'm all ears.....
-G
Old Feb 1, 2013 | 05:52 PM
  #112
Mackhack's Avatar
I hope you guys are aware that the OBD connector isn't intended to power devices under constant load. Same as when people connect coffee cup heater plates and monitor Christmas lighting to their USB ports. It is a data port (OBD and USB) and not a power source!
Old Feb 1, 2013 | 10:06 PM
  #113
NCBob's Avatar
Mack,
As successful as Valentine has been over the last decade, I feel confident that he's done his research. I've done a lot of research using the OBD and have seen no problems with using the OBD for a power source. The Valentine does not draw much power. Tiny wires are used as a power source using standard phone wires. If fuses blow and or smoke comes from the OBD, I'll be sure to report it here. If the OBD is needed for another function, unplug the Savvy. Right now, I'm sold.
15 minutes of work and so far it works great.
Old Feb 2, 2013 | 07:17 AM
  #114
GregMB's Avatar
I definitely love the functionality of the SAVVY.
I've owned the V1 detectors for 20+ years, but was getting REALLY tired of the "around town mute dance" that I'd have to play with it due to constant falsing near banks, automatic doors, etc.
Being able to set a threshold at 45mph to shut it up for city driving has been a Godsend...... Peace and quiet when want it, highway protection when I desperately need it.
-G
Old Jul 17, 2013 | 12:38 AM
  #115
Tremek's Avatar
'17 GLS 63 AMG, '08 S65 AMG
V1 installed last night:
Ordered a 6 foot long 12v non-coiled power cable off Amazon (it was not flat as I was hoping, but round) and ran it down the passenger side headliner, into the A-pillar and used my trim tools to wedge it behind the trim and down the door side of the A-pillar, behind the removable panel on the edge of the dash that meets the door, and finally to power that I ran from the 12v plug in the center of the dash behind my glove box. Works great!
Old Jul 17, 2013 | 11:11 AM
  #116
09W211's Avatar
2009 W211 E350 AMG Sport PKG
i have the weirdest problem with mine. for some odd reason, my V1 will only stay on when my headlight switch isn't in the auto position. when it's in the auto position, it turns on but turns off right after and only turns back on when my car goes under a bridge or parks under the garage.
my V1 is hardwired and tapped into the cigarette lighter as well.
Old Jul 17, 2013 | 12:05 PM
  #117
Tremek's Avatar
Hmmmm... There's 3 wires going into the back of the cigarette plug, is it possible you tapped into the wire for the light in the cigarette lighter ring surround, instead of the red wire? Sounds like the light sensor is turning on the car's lights and that might be your hot wire for the V1 (the light in the cigarette lighter surround going on probably correlates with the V1 turning on?)
Old Jul 17, 2013 | 04:36 PM
  #118
09W211's Avatar
Tremek: that makes perfect sense. i will have to take a look at where its tapped into. thank you!
Old Jul 17, 2013 | 08:03 PM
  #119
Mackhack's Avatar
For all of you who don't know but I'm building custom made wiring harnesses for the V1! No running down to ash tray, A-Pillar or the like.
If you want one shoot me a PM for pricing and info! Power is switched so your V1 doesn't drain the battery (anything else would be stupid in the first place)!!!
Old Jul 18, 2013 | 12:19 PM
  #120
09W211's Avatar
would you mind providing more information of your custom made wiring harnesses? i thought i'd ask here instead of a PM so you don't have to explain the harness multiple times.
Old Jul 18, 2013 | 02:03 PM
  #121
Mackhack's Avatar
The harness is built so you can use the overhead control module (part where the light switches and sun roof switch is located) for switched power. No soldering or clipping wires required.
Nice, clean approach to hook up the best radar detector that money can buy on earth in the best engineered cars on this planet
Old Mar 23, 2015 | 10:24 PM
  #122
scola888's Avatar
07 E63 AMG
Passport 8500 X50 Hardwire...
Many thanks to both the author and contributors on this post. I was able to hardwire my 8500 X50 this evening with minimal fuss. I tapped into the +12v sw behind the cigarette lighter using a Passport Hardwire kit. I ran mounted the remote switch on the passenger side of center console for easy access. I ran the wires up the passenger side and tucked into A pillar and headliner.
Thanks again all, very happy with the final product!
Old Mar 24, 2015 | 02:21 PM
  #123
Honcho's Avatar
'03 SL55 AMG | 2021 AMG GLE 63s Coupe
Has anyone gone in from "below"? I get perfectly fine reception having my 9500ix mounted just above the dash, and I prefer it there for a few reasons.
So bypassing the placement discussion, how best do I route the hardwired power? I had two thoughts right off:
1.) Go through the center mounted speaker, but that would require making a notch in the grille, which seems a bit risky, but probably not as risky as option 2.
or
2.) Drill a hole through the dash along the recessed vent line where the defroster vents are.... but I'm not sure what I'd be getting into with that.
I'm also thinking about scrapping the plain hardwired power cord that I have, and getting the "smart" cord so that I have the little "silence/memorize" button a bit more within reach, and mounting that in the ashtray, but not sure if it's worth it.
Anyone gone this route, or have useful information?
Old Mar 24, 2015 | 07:59 PM
  #124
Mackhack's Avatar
Why drilling holes when my harness doesn't require it? Sure it's not where you want it to be then but much better solution.
Old Mar 31, 2015 | 09:47 PM
  #125
Honcho's Avatar
For anyone else that wants to install it low.... five minutes with a Dremel tool this past weekend, and I had a nice clean little notch in the center speaker grille, and snaking the smart cord to the lighter was easy as pie. Mounted the remote next to the lighter and I couldn't be happier!
