FM antenna location? (03 E500)
1 Post
E500, Viper, and other less-fun stuff
Does anyone know where the FM antenna is located? I have an 03 E500 without COMAND. Basically this car is my beater, so I'm not about to burn $2K just to play MP3s. I was rather disappointed that the stereo doesn't have AUX, and not having MP3 playback is no fun at all -- we have it in all our other vehicles. Heck, I even have a hookup for my motorcycle intercom system.
I know FM transmitters aren't well-received around here (no pun intended) but many years ago I used a JVC transmitter for a JVC CD-changer it worked perfectly -- in fact, you couldn't tell it wasn't hardwired. Hoping to do the same thing in the Benz, I bought a transmitter at BestBuy the other day and unfortunately the results were disappointing. Lots of static. My "installation" at this point is simply plugging everything into a cig lighter and resting the mess on the passenger seat, but if I can find something that works I'll do a cleaner hardwired install, which leads me to my antenna question.
I suspect the FM antenna may be in the rear of the car because I get a lot of radio noise whenever I use the rear defroster. I can't imagine the defroster cranks out so much power that it interferes with an antenna several feet away (particularly considering how poorly the defroster works). If that's the case, I'll try relocating the transmitter back there, and if it improves enough to be usable, I'll permanently hook it up that way.
No, this isn't an iPod, and I know they have the same kind of thing available, but I personally think the iPod interface is crap. With apologies to anybody who has one and likes it. Just getting the inevitable questions out of the way up front. Also if anybody knows of a reliable, reasonably priced FM transmitter that might simply work better than my BestBuy $20 deal, please do post. It wouldn't surprise me at all if the thing I bought is simply underpowered.
2003 E500 Sport
I'm pretty sure the antenna is located in the rear window, which explains the interference from the defroster.
I am also pretty sure you can add an AUX jack in the glove box. There have been a couple posts discussing this, one with a good how-to complete with pics. Do a search, because I think that's the answer.
I believe the top six (6) lines of the defroster grid are the FM antenna; however, more importantly, regarding the following:
If you're getting ANY kind of static/noise when using the defroster, take your w211 in for service - there's a fix for that (I think it was the audio gateway replacement?).
GL.
GL.
2004 E500 / 2001 C240
This is what you want.. I work at ATS, so let me know if you want it, or buy ot from someone in The States.
http://www.ats-systems.com/store/det...D=ATS-H-MP5230
It has to be the Tunecast II so that you can set it on any FM station you want.
Build date 2-04 E500
GL.
1 Post
Thanks everyone.
hilmar2k -- I'm pretty sure you can't add AUX to non-COMAND systems but I'll double-check.
Miguk -- I had read about static and noise problems but I hadn't seen anything related to defrost usage. Thanks for the tip, I'll look into it.
ATS -- Do they make one which runs off 12V power?
1 Post
Originally Posted by HELL ONA HARLEY
Actually the fix is a rear window replacement.... I Have the same problem with mine but won't let them touch it....The antenna wire is broke somewhere within the rear glass.
