is $493 a fair price for lowering?
Also I noticed that the back end may drop lower than the front end, but the front end rides a lot higher ????? Is this normal? Will it balance out at the end?
In stock form the rear rides higher than front. eibach lowers the rear more to compensate for this so your car will be evenlly lowered when done.
they were also mumbling about the spacers/perches on top of the springs that have different heights...
maybe i should just buy a e500
Coil springs would solve that issue. If not the coil springs, ask them about new shocks and see if they think it is necessary, after all they are in there anyway.
A good set of coils will be about $1,000 to 1,500 and many have adjustable ride heights. The price you quoted seems low unless you mean per wheel.
Good luck
