E-Class (W211) 2003-2009
Dumb bi-xenon headlight question. When the low beams (m)
Old Jun 12, 2005 | 09:39 PM
JWS3's Avatar
2004 E500
are on, all that is engaged are the xenons. When the hi beams are engaged, however, the inner lights, which appear to be halogen and used for "Flash to pass" also turn on. Why? One would think that with bi-xenons such wouldn't be needed. Any ideas?
thanks-
Jim
Old Jun 13, 2005 | 03:53 AM
Dvinn's Avatar
03 E500
Our cars bi Xeons are not what most people think it is, it still use the inner headlights for high beam - using halogen bulbs.
Old Jun 13, 2005 | 10:54 AM
Kev04C320's Avatar
'09 911 C4S
BiXenon only means that there is a diaphragm in your headlight, and when you turn on the hi beams, the diaphragm switches into a different configuration, thereby projecting more of the HID lights to the upper portion of the light pattern. The halogens are considered as AUXILLARY hi beams. It is explained clearly in your owner's manual.
Old Jun 13, 2005 | 01:13 PM
Brian_I.'s Avatar
w211 & w124
I never fully understood that, thanks for the clarification. In the BMW's, the "diaphragm" provides the full high beam therefore no need for any "auxillary" halogens.
Old Jun 13, 2005 | 07:38 PM
JWS3's Avatar
2004 E500
Interesting. After 4 BMWs I was used to a
different concept of bi-xenons. With BMW, the halogens were only used for flash to pass.
Old Jun 13, 2005 | 07:47 PM
mbbodytech's Avatar
04 C320 Coupe MT
The only reason for the inner halogen lights is for flashing to pass when the low beams aren't on. You will still hear the solenoids moving when you flash the high beams when the low beams are off.
The reason for that is xenons aren't instant on and off like halogens can be.
Old Jun 13, 2005 | 08:51 PM
JWS3's Avatar
2004 E500
Um, where exactly in the rather voluminous
manual did you find this? I'm still stuck at Vol XI, chapter 23 of the manual....
Old Jun 13, 2005 | 09:06 PM
HotWheels500's Avatar
'05 E500 4-Matic Wagon
Point is, MB Xenon/halogen headlights on the E are just about the best factory lighting you get on any car. Enjoy it.
Old Jun 13, 2005 | 09:10 PM
HELL ONA HARLEY's Avatar
Build date 2-04 E500
And add the active feature, then they are the best by far....
Old Jun 13, 2005 | 09:55 PM
Couldn't agree more. The actives really work. Amazing!
