E-Class (W211) 2003-2009
Only had car 1 week and already first problem!
Old 06-25-2005, 09:13 AM
99c280sport's Avatar
What the heck is the deal? This is actually only the 4th time I've driven the car and now out of nowhere there is this embarasssing creaking coming from the brakes. Whenever the brake pedal is pushed the noise can be heard inside and outside the vehicle. It doesn't do it when the vehicle is off and I pump the brakes, only when it's running.
Anybody have any idea what this is?
Gary
Old 06-25-2005, 09:15 AM
This is the 05 E500 not my c280
Old 06-25-2005, 09:45 AM
CE750's Avatar
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
new brakes will squeak for a few days sometimes, is that what you have? or are the making other than a squeak? what do you mean creaking?
Old 06-25-2005, 10:11 AM
HELL ONA HARLEY's Avatar
Build date 2-04 E500
Sounds like your experiencing the SBC brake "groan".... This would be heard and sometimes felt about every third brake application usually when the car is at a stand still. Its the brake pump running to keep presure in the system. Some cars seem to be worse than others. There is a fix and it will be done for free. Complain to your dealer about the problem and ask about the SBC brake damper kit. The kit works well.
A quick search under (SBC brake) should yield some good reading.
Good luck with your new ride.
Old 06-25-2005, 11:18 AM
It's not the pads themselves it's more like Hell on a Harley said it's probably some sort of SBC problem. Like some kind of servo or pump. It's a creaky noise when the pedal is pushed. Actually sounds like it's coming from under the dash.
Old 06-25-2005, 12:55 PM
After searching I found Service Bulletin # 424643
Where can I find the info on this bulletin. It's supposedly for a squeaky brake
pedal.
Old 06-25-2005, 01:00 PM
MBE55AMG's Avatar
'03 Yukon XL Denali, '06 Eclipse GS
Problems don't necessarily have to come in time...
Hope it gets fixed.
Old 06-25-2005, 01:05 PM
lig
lig's Avatar
was '03 E320 - now - '04 S4
Defintely sounds like the SBC groan to me.
Old 06-25-2005, 02:36 PM
CE750's Avatar
Hope it gets fixed.
This has definitely been my observation with airplanes... first month is guaranteed to find a bunch of bugs.. assembly process causes a lot of problems.
Old 06-25-2005, 02:46 PM
The SBC "groan" is completly normal and funtioning as designed. The pump is located under the hood so you may think its coming from the dash area. As I stated earlier, some cars are a little worse than others. My car was not that bad and really didn't bother me but after reading here in this forum about a in line damper kit I decided to have it installed (free of charge) during a regular service interval. I must say it did help and I never notice it anymore since the upgrade.
Good luck and I'm sure it will work out for you.
Old 06-26-2005, 06:06 AM
D-5
D-5's Avatar
2003 E55
I have the same noise as you described on my 2003 E55. It is not the buzzing noise from the SBC pump. Same thing, the creaky noise is coming from somewhere around the dash when braking. I can't hear it in traffic, only in residential area when parking my car, especially when backing up into my garage at night.
Old 06-26-2005, 12:48 PM
RunninRS's Avatar
My new E500 did the exact same thing.. creaky/squeaky noise when the brakes were applied. When I went to pick up my car, I noticed the dealer had sprayed some sort of stuff on my tires to make them shiney (man I hate that). Now that all of it has spun off onto the body (grrr) and I have driven the car 500 miles or so, the noise is totally gone. It's possible in my case they got that spray gook onto the brake mechanism somehow. Who knows. I have had the car 1 week so far.
This noise is totally different than the brake groan, which I also get sometimes sitting at a light waiting for others to move.
Old 06-26-2005, 11:06 PM
That's funny cuz my tires still have that shiny stuff on them from when the dealer detailed the car when I purchased it last week. Coincidence or maybe that's what's causing this squeak.
I took it out this morning and at first there wasn't any noise but after I finished breakfast and returned home it was there again. Weird!
Old 06-27-2005, 12:23 AM
BudC's Avatar
2011 E550, 2013 GLK
Component Description:
7. SERVICE BRAKES, HYDRAULIC
Bulletin Number: 424643
Bulletin Date: JUN 2004
Vehicle: 2004 Mercedes-Benz E-Class
Summary:
SQUEAKING NOISE WHEN GENTLY APPLYING BRAKE. MODEL 211 MY2005 ALSO INCLUDED. *TT
Old 07-01-2005, 06:52 AM
Petmerctech's Avatar
That doesn't sound like SBC groan. There is a program in DAS under the SBC section that specifically deals with brake pedal noises. Ask your dealer to have the procedure performed.
Quick Reply: Only had car 1 week and already first problem!
