E-Class (W211) 2003-2009
E55 Brakes on a E500??
Old Jul 5, 2005 | 02:29 AM
droppedW211's Avatar
2005 E500 with E55 bodykit, E55 AMG exhaust, Lorinser trunk lid spoiler, 20" Iforged wheels
Interested in putting on the E55 AMG cross drilled brakes and rotors on my E500. Has anyone done this? Results? Any advise on where to get these parts cheap?
I guess I will need the rotors, calipers, pads, and brake lines. My mechanic will install the parts. Thanks in advance.
Old Jul 5, 2005 | 03:58 AM
F1Fan's Avatar
Doesn't the E55 and the E500 have different wheel sizes? If so, are you sure the new brakes and rotors will clear the wheels you have? Lastly, what about the spare tire. If you upgrade the brakes and rotos to a bigger size, the spare may not fit anymore.
Old Jul 5, 2005 | 04:13 AM
Frank Wiesmann's Avatar
Spare tire
I don't think we have spare tires anymore. My 2003 E-Class has a tire repair kit with some sort of pump and fluid to seal the hole.
Old Jul 5, 2005 | 08:29 AM
Kev04C320's Avatar
'09 911 C4S
You can replace both the calipers and the rotors on your E500 with the ones from the E55. However, you would need to upgrade your wheels to 18s in order to clear the massive 8-piston front caliper. As discussed previously, this upgrade is mostly for looks only.
Old Jul 5, 2005 | 11:29 AM
The clearance issue is not a problem. I have 20" wheels on the car. It looks like all of you guys are not too thrilled with the idea. No performance advantages going with the E55 AMG brakes?
Old Jul 5, 2005 | 11:30 AM
ATS's Avatar
ATS
2004 E500 / 2001 C240
This would be incredibly expensive. If you do get it done, let me know the cost. I could see if being around 5-10 thousand, not including the wheels...
Old Jul 5, 2005 | 12:27 PM
Kev04C320's Avatar
'09 911 C4S
Actually, the cost to replace the brakes are not that bad, say around 3K for parts alone. The installation is easy too since it's just bolt on parts anyways.
droppedW211: I would do it just for the looks and am planning to do it. If you are interested in performance gain, consider the new EVOSPORT drilled / slotted 2-piece brake disc upgrade. At least those have correct cooling slots, unlike the stock AMG rotors where one side the cooling slots are installed in reverse, plus they are almost 100lbs (total) lighter than stock rotors. Lower unsprung weight = better performance
Old Jul 5, 2005 | 12:35 PM
ATS's Avatar
ATS
Do you have a link for the rotors? It appears they have them for W210 not W211.
Old Jul 5, 2005 | 12:36 PM
DWP's Avatar
DWP
'08 AM Vantage V8 - '03 E500
Are you absolutely, positively, sure that your friendly mechanic can swap the brakes that came with your car, for brake parts that didn't, without compromising braking perfomance in some way?
Whether you should spend thousands of dollars to change the look of your brakes is your business - unless a failure of that critical system causes an accident. Then it's not just your business any more.
Old Jul 5, 2005 | 12:46 PM
Kev04C320's Avatar
'09 911 C4S
Go lecture the W203 owners that have swapped C32 AMG front brakes first..... (edit: and how about those that have BBK?)
The parts are direct swap and in ROW those brakes are offered as factory AMG upgrades. In the US of A, any lawyer can sue anything they want, no matter what.
Old Jul 5, 2005 | 12:48 PM
Kev04C320's Avatar
'09 911 C4S
https://mbworld.org/forums/showthrea...vosport+rotors
See this thread for an actual picture of the rotors.
Old Jul 5, 2005 | 01:12 PM
DWP's Avatar
DWP
No problem. You're 3000 miles away from me.
Old Jul 5, 2005 | 01:23 PM
amgkoo's Avatar
'12 CLS550, '08 M6, '04 E500
Give Sander at TWS a call: http://www.thewheelsupply.com/index.jsp
I know they sell these at good price. They also have customers who replaced E55 brakes with bigger Brembo brakes and you might be able to find some used ones cheap.
Old Jul 5, 2005 | 02:13 PM
jameson75's Avatar
2005 E500 / 1993 MR2 Turbo
Instead of getting the E55 brake setup, why don't you get the Brembo brake kit. Its probably better than the E55 setup, since the bremo's will be made for the E500, instead of trying to get an E55 setup to fit on an E500. You'll most likely end up paying less for these aftermarket brakes versus paying a dealer to buy the E55 brake set.
BTW, "dropped" you mentioned that you are rolling on 20"s. I am considering putting 20's on my E500 as well, what kind of wheels are you on? Do you have any issue of rubbing or any other problems?
Old Jul 5, 2005 | 03:11 PM
I have the Iforged rims. No rubbing problems. You need to shave the bolts on the control arm though.
Old Jul 5, 2005 | 10:09 PM
jameson75's Avatar
Old Jan 3, 2007 | 02:18 PM
D2-AUTOSPORT's Avatar
Former Vendor of MBWorld
VIPER
Sorry to bump an old thread but has this been done yet?
Old Jan 3, 2007 | 07:02 PM
MARK CUMMINS's Avatar
209/W210 Estate /W211 modded by MBENZNL
Its Been Done
I Did The Wifes 06 W211 Installed the AMG E55 Brakes ...on the front the spindles must be changed or remove them and drill the caliper mounting holes as the NON AMG Cars do NOT have the correct size holes in the spindles for the AMG Caliper bolts...The Bolts have a LARGER DIA Shoulder on them
Btw I Will Be selling the LARGE Front Brakes Calipers/rotors/pads with 7K on them (AMG) to Install a set of the 030 LARGER front AMG Brakes on the wifes car PM If Interested
Old Jan 4, 2007 | 10:25 AM
TECHNICIAN's Avatar
S 63 Coupe, GLS 63
I'm interested....how much?
Old Jan 4, 2007 | 04:30 PM
PM Sent
Old Jan 12, 2007 | 02:48 PM
Jon@Jlevi SW's Avatar
I would just upgrade to a Brembo system...
Contact us for Pricing.
JL
Old Jan 15, 2007 | 10:35 PM
kenkenbenz's Avatar
Originally Posted by MARK CUMMINS
Its Been Done
Did you do the work yourself? if so, how did you bleed the fluid? Do you or anyone know if it is possible to bleed the brake fluid with out the use of STAR Diagnosis tool?
Old Jan 16, 2007 | 10:51 AM
Yes I Did The Work myself...Its Not that hard..With The Correct Tools!
One Can bleed the brakes without using the star....Just cycle the sbc pump...
Open a door or pump the brake pedal to cycle the pump....Used OE MB Brake fluid
I Checked for any codes and None were found
Old Jan 16, 2007 | 12:56 PM
kenkenbenz's Avatar
Mark,
Thanks for the info, I sent you a PM
Old Jan 16, 2007 | 04:59 PM
konigstiger's Avatar
'71 Pinto
Just so everyone is aware.
DTB P-B-42.46/46c SBC Bleeding Procedure AUG05
If the brake system has been opened, then the brakes must be bled and checked for air using STAR Diagnosis “Bleed Brake System” and “Inspect Brake System for Air” functions before brake system is activated again. Failure to do so can lead to malfunctions of the brake system. The specialized brake bleeding procedure of the SBC system requires that specific Service Equipment and/or Special Tools be used in order to effectively bleed the SBC system.
