Mercedes-Benz factory ride height adjustment shims
Mercedes-Benz cars ride height may vary due to vehicle options and Mercedes-Benz factory ride height adjustment shims. This original-MB-Part is a rubber shim perch, which is located on the top of the spring. These shims vary in thickness from 8 to 23mm.
Question: What is thikness of the factory installed shims on my W211, no airmatic, no sport package. I figure that if its closer to 23mm then I have 15mm to play with.
Thanks!
Thanks!
the part no are following:
A211 325 01 84 5 mm
A211 325 02 84 9 mm
A211 325 03 84 13 mm (original)
A211 325 04 84 17 mm (currectly I play with)
A211 325 05 84 21 mm
Moreover, even I changed from 13mm to 17mm wich only jyst 4mm difference
however after aligement it is about 8mm higher
Thanks!
For example my car is 192 points and a C32 is about 220. So even if I get C32 springs and put them on my car then my car is far too light for that spring rebound.
In terms of shim then there are 2 types for normal and sports package / avantgarde. The AMG ones are the same as sports package.
The thickness is reliant on the factory calculation but it will always be too high for someone who wants a lowered ride. So you will most likely need the 8mm version.
