E-Class (W211) 2003-2009
Rear brake pads and rotor needed at 21000 miles??
Old Oct 10, 2005 | 12:38 PM
allen_7's Avatar
2016 E350, 2013 C300 4MATIC, 2004.5 C230SS
Just got a call from MB service dept that my MY04 E500 needs both the rear brake pads and rotor. Front brake pads and rotor are still good.
On all my previous cars the front brake pads also goes out first and the rotor is not due for replacement until the second set of brake pads are done. Rear brake pads and rotor can usually last much longer than the front.
My car has 21000 miles on it, is this normal?
Old Oct 10, 2005 | 01:00 PM
BudC's Avatar
2011 E550, 2013 GLK
The SBC system applies the rear brakes far more than with with older systems. I think Mercedes have come out with new pads for the rear brakes that are supposed to last longer.
I'd verify that your dealer really needs to change the rotors. I can't believe they are gone this fast.
Old Oct 10, 2005 | 01:04 PM
TPAbnz's Avatar
2017 E300W
How much do they want for the job?
Old Oct 10, 2005 | 01:08 PM
allen_7's Avatar
$254 parts and $250 labor.
Old Oct 10, 2005 | 01:10 PM
allen_7's Avatar
I am thinking I should get a second opinion from another shop.
Old Oct 10, 2005 | 01:23 PM
BudC's Avatar
2011 E550, 2013 GLK
A set of Pagid rear pads retail for $66 and can be had on the Internet for about $55. Zimmermann rotors retail for $51 and can be had on the Internet for $42. The right rear sensor lists for $6.50 and can be had for $5.77. That's a total of $168 list for the parts.
The dealer is charging you 2.5 hours labor. I'll bet it doesn't take them half that to do the job, especially with a lift and impact wrench.
I'll bet your rotors are OK but the dealer is estimating that they won't last until your next service which could be quite a while.
Old Oct 10, 2005 | 01:28 PM
SAguirre's Avatar
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
I could not have said it better myself. I would negotiate on the price with the dealer, ask them what the thickness and the run out of the rear rotors is and see if they can keep them on. Otherwise, I would try and find a very reputable shop that knows how to work on SBC brakes.
I am planning on changing my own brakes when I need them, but at this pace it will not be for a long time.
Steve
Old Oct 10, 2005 | 02:29 PM
csumt76's Avatar
LS7 powered Corvette
I would bet $100 that the rear rotors indeed need replacement. There are two thickness' that can be found in WIS. One is the min. thickness @service and the other is the absolute minimum which is also stamped on the rotor. At 21K you are likely within a couple tenths of a millimeter of the absolute minimum if not below it. If you just do pads, the rotors will be completely gone by the next time you run out the pads. I would say that 20-25K is about the average life of the rear brakes depending on driving style. Just ask to see the old parts and see the measurements. Not replacing the discs also increases the chance of noise.
Old Oct 10, 2005 | 02:50 PM
Flash Gordon's Avatar
2003 E500, 2004 G35X
There are good independent shops in most metro areas. They usually work on MB, Bimmers,etc. I would suggest you do a little research in your area. I will be frank with you. Most of us tend to give too much credit to these dealers techs. My experience with two big dealers in my area is disappointing. Both of them have screwed up my warranty service that I have to bring the car back at least twice. I will still take my car to the dealer for warranty service, but after the warranty is over, I am taking it to a local specialist.
To replace rotors at 21K is just hard to believe! I have 26K on mine and no brake issues. Having said that, I knocked my wood table!
Old Oct 10, 2005 | 03:24 PM
BudC's Avatar
2011 E550, 2013 GLK
Boy is this thread depressing. I guess the days of 70K on rear pads are gone. I guess the days of 80K on front rotors are gone. I guess the days of $20 rear pads are gone.
Anybody want to buy a nice clean W211
Old Oct 10, 2005 | 03:28 PM
allen_7's Avatar
Got a link for the parts?
Exactly what I was thinking. I question their capability 'cause they never seems to find the problem I complains about and I had to bring back the car repeatedly.
Do you know the minimum thickness for the rear rotor?
Old Oct 10, 2005 | 03:32 PM
BudC's Avatar
2011 E550, 2013 GLK
Here's one..
http://www.buymbparts.com/
Old Oct 10, 2005 | 03:33 PM
allen_7's Avatar
May be this is the reason why MB's bumper-to-bumper service doesn't cover brake and rotor like BMW's does.
Old Oct 10, 2005 | 03:35 PM
allen_7's Avatar
Thanks.
Old Oct 10, 2005 | 03:39 PM
BudC's Avatar
2011 E550, 2013 GLK
God I hate Chris Bangle for messing up the 5'er. I woulda, coulda, shoulda bought a 545i.
Old Oct 10, 2005 | 09:09 PM
csumt76's Avatar
I would have to look it up... I can't remember exactly. I don't do a whole lot of brake jobs, mostly electrical and cars with less than 20K.. I rarely reccomend brakes unless they are damn close to the wear sensors, just my preference.
Old Oct 10, 2005 | 09:16 PM
HELL ONA HARLEY's Avatar
Build date 2-04 E500
My car with 22,000 on it needed just front brake pads (no rotors).... and no brakes or rotors at all on the rear side.... Go figure
Old Oct 10, 2005 | 11:55 PM
allen_7's Avatar
Just got my car back from the dealer, rear rotor does look kind of thin. I will take it to a MB specalist tomorrow for their opinion.
The minimum thickness is 8.3mm, it is etched on the rotor.
Dealer performed the SBC Hydraulic unit compaign during this visit. When I pulled into the car into the gas station (I had 3 bars left in the tank when I took it in, it's empty when I picked it up and they put 11 miles on it), I noticed a grinding/pinching sound from the front end whenever I applying the brake....need to bring it back again........
Old Oct 10, 2005 | 11:59 PM
vraa's Avatar
Nope. I just got all my pads and rotors changed on my X5 @ 16k miles.
CE750's Avatar
'05 E320 CDI, '08 BMW X5 4.8i, '11 Duramax 2500HD
new rotors at 22K doesn't sound right... do you abuse your brakes? I would guess they're good for 50K or more..
Old Oct 11, 2005 | 12:02 AM
vraa's Avatar
Well maybe he's had a rainy season. Remember the SBC automatically 'dries' the rotors and pads.
Old Oct 11, 2005 | 12:05 AM
allen_7's Avatar
Did they cost you anything?
A friend of mine used to sale BMW and he told me BMW warranty covers brakes and rotors.
Old Oct 11, 2005 | 12:07 AM
MB Fanatic's Avatar
4 wheels
Who is your dealer?
And BudC is on target, SBC will wear the rear brakes faster than the fronts. However having to change rotors this early would indicate that something is wrong with SBC or your dealer is trying to shaft you.
Old Oct 11, 2005 | 12:09 AM
allen_7's Avatar
Not at all.
Dealer mechanic said I have 50% front and 5% left on the back. If I abuse it in any way I would still think the front will wear out much faster than the rear.
Old Oct 11, 2005 | 12:10 AM
CE750's Avatar
Not at all.
odd, very odd.
