E-Class (W211) 2003-2009
First issue today
Old Oct 11, 2005 | 12:19 AM
jameson75's Avatar
2005 E500 / 1993 MR2 Turbo
First issue today
Had my first problem today. don't know if its going to be a major issue, but while driving today, the SRS malfunction light came on, haven't heard anything from the dealer yet. will know tomorrow.
has anyone encountered such an issue, and if so, what was the problem
thanks
Old Oct 11, 2005 | 12:51 AM
lig's Avatar
lig
was '03 E320 - now - '04 S4
Had it happen three or four times. It went away after a day or two every time. Had so many MFD warnings of all varieties that I basically ignored them after while.
Think of your as being like a Windows computer. When it gives you a goofy warning - most of the time a "restart" generally takes care of it.
Old Oct 11, 2005 | 08:39 AM
xraymd's Avatar
2008 335 vert, 2004 MDX
Did you get the red light in the dash drive it to a service center warning? I and a few others have had that and the fix has been a new watch spring in the steering column. They can fix it in half a day.
Old Oct 11, 2005 | 08:55 AM
TPAbnz's Avatar
2017 E300W
Check your "Messages" section on the MFD. If the warning's not retained, I wouldn't worry about it.
Old Oct 11, 2005 | 12:38 PM
jameson75's Avatar
Yeah its the SRS malfunction display and it says drive to service shop. and yes the warning stays in the message box. haven't heard from the dealer yet, i'll let you know what they say later today. BTW, what clock spring in the steering column are you talking about? thanks
Old Oct 11, 2005 | 12:49 PM
konigstiger's Avatar
'71 Pinto
Originally Posted by jameson75
Yeah its the SRS malfunction display and it says drive to service shop. and yes the warning stays in the message box. haven't heard from the dealer yet, i'll let you know what they say later today. BTW, what watch spring in the steering column are you talking about? thanks
More than likely the sensor (steering column) needs to be replaced. Believe it or not many CLS models were shipped from the factory with defective sensors producing the very same malfunction.
Old Oct 11, 2005 | 02:57 PM
xraymd's Avatar
I just read my old posts and it's actually a "clock spring". Here's some prior posts. For better or worse, you're not alone
connector problem
clock spring
Old Oct 11, 2005 | 04:29 PM
jameson75's Avatar
the service advisor just called and said that the culprit is the SRS module, which they are replacing. Meanwhile they also fixed a recall with something he called a battery control module.
Old Oct 11, 2005 | 10:48 PM
xraymd's Avatar
Ah, something different for the SRS warning. Do a search of the forum for the battery control module recall. There have been problems after it's done.
https://mbworld.org/forums/e-class-w211/122775-my-first-malfuntion-update.html
