Anyone Attempted to Install LED Turn Signals?
Has anyone replaced their rear turn signals with LED's? There is a site: www.superbrightleds.com but I wouldn't know where to start and even if these would work in a car. Any input?
1967 Morris Cooper "S", 1983 911SC, 1997 Toyota Tacoma, 1999 HD FXSTB, 1998 C43
Look up load equalizers....if you don't have 'em you'll light up the bulb failure lamp on the dashboard.
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
I am contemplating the change over to LED stop lights, this will require me changing the whole taillight assembly. I might look at the old circuit board and see how this could be possible. But, this would be a summer project.
This new design means that if you burn out one light bulb, you will need to replace all on that side! I usually always replace the set of lights that burns out, that means that if 1 of the 4 rear parking lights burns out, I replace all of them and keep a few as spares. I figure that they all worked equally as long and if one burns out, the others should be close to that point. Also, you are making that whole rear set have the exact same intensity.
I think that this makes these W211 light bulbs expensive since each side costs about $50.00 and once one burns out I will probably change both sides. I wonder if you would have to replace the LED panel (the stop light part) if one of the reverse, blinker or parking lights burns out on that same side? Hopefully, the LED taillights have this part separated.
I will investigate this further once I get to at least changing my taillights,
Steve
Darn. I was hoping this was just plug and play. I never guessed that it would be so complicated. That is a good idea to replace both when one goes out. If you are going to go to the trouble you might as well replace them all.
Anyway, thanks for the advice!
2006 E350 4Matic, 1990 300SE, 1984 190E, 1994 BMW 540ia
LED brake lights make sense so you get an immediate response on braking......LED turn signals would look super cool but I don't think the effort would be worth it. Lot of man hours. Gotta say though it looks way cool on those E46 3-series BMWs!
Originally Posted by rockyfeller
LED turn signals would look super cool...Gotta say though it looks way cool on those E46 3-series BMWs!
All Diesel Fleet !1983 240d stick,2005 E320 CDI Midnight blue, 2005 E320 CDI, Desert Silver, Kubota
Old Volkswagen Turn Signals
You younger guys don't remember, but the coolest turn signals of all time were on the early VW beetles. A lighted turn lever came down from near the roof line and stuck out 6-8 inches. You knew they were turning!!
06 320E CDI, Porsche 911 C2, Pontiac Montana
Turn signals are over rated. I never use mine (saves on finger wear) and yet I NEVER caused a pile up.
Funny you guys should bring this up. I was also admiring some on a truck the other night. They were so bright that they were actually starting to blind me.
Have you guys ever followed another E-class? Believe me, our back lights don't take second place to anyone.
