E-Class (W211) 2003-2009
Help! 2003 E500 diesel knock on V8??
Old Apr 5, 2006 | 05:38 PM
dknj23's Avatar
'23 EQS 450, '22 Tesla MYP, '21 992S
Can you fellow 2003 E 500 owners tell me if a slight diesel type knock is typical for this model? I hear it around 1500 -2000 rpm's. Dealer says that this is how the engine sounds. Engine management- CPU says nothing wrong.
Old Apr 5, 2006 | 05:54 PM
RobertG's Avatar
things with and without wheels
What kind of fuel are you using? ( octane)
KosherBenz's Avatar
Its big and Grey!
Old Apr 5, 2006 | 05:59 PM
dknj23's Avatar
using 91-93 Can only hear it from around 1500-2000 rpms. When the car is in park and you rev the engine no noise.
Old Apr 5, 2006 | 06:05 PM
RobertG's Avatar
You might be hearing a lifter noise, do a search on that topic
Old Apr 5, 2006 | 06:36 PM
konigstiger's Avatar
'71 Pinto
It sounds like they need to replace the motor mounts:
P-B-07-00/21f - JUL03 2003 E500 Engine Noise
Engine ticking (piston slap like sound) noise complaints when accelerating between 1200 & 300 rpm, replace motor mounts with modified motor mount part # 220 240 05 17 and reset flywheel adaptation.
Old Apr 5, 2006 | 07:40 PM
dknj23's Avatar
Thanks for your inout. Doing a search on the forum on this. question i have is how can a bad motor mount cause the noise. Thinking the lifter makes more sense. If you can explain that would be helpful.
TIA
Old Apr 5, 2006 | 07:51 PM
'71 Pinto
Read through this search from last page on and this should explain:
https://mbworld.org/forums/search.ph...2&pp=25&page=4
Old Apr 6, 2006 | 11:26 AM
DaveFr's Avatar
03 E500 Sport, Pewter/Charcoal
Dan,
I just looked up the TSB and here's the language for E500's:
For E500 a modified motor mount, part no.211 240 05 17, is installed as of chassis no. A224352. On vehicles prior to this chassis no., remove part no. 230 240 00 17 and replace with part no. 211 240 05 17.
Reset the flywheel adaptation.
Note : On vehicles E500 (211.070), warranty claims will only be accepted from vehicles with chassis no. A224352 and lower.
Old Apr 6, 2006 | 11:07 PM
DesiBaba's Avatar
C240
Bad engine mounts for sure, i had the same problem...and for the life of me i couldn't figure out. My SA always told me thats how it suppose to sound, but then one day i took one of the tech out for a ride, he instantly pointed out Bad engine mounts, since then life couldn't be better. Make sure you get this done before warranty expires, or else i think it suppose to cost about $1200-$1400. Good Luck.
Old Apr 7, 2006 | 05:50 PM
dknj23's Avatar
have appt on the 18th. will let you know how it turns out. thanks all
Old Apr 19, 2006 | 06:33 PM
dknj23's Avatar
Just got the car back. The motor mounts did the trick! No more diesel sound.
Also i had a slight squeak at low speed from my brakes and ended up getting both front spring clips replaced. That did the trick.
Lastly managed to squeeze in my last service before 50K came up.
Did this all at Catena under warranty, service there is excellent.
Tommorrow will be putting on 19's AMG style. Maybe i'll post pics.
Thanks all for your input.
Old Apr 19, 2006 | 06:57 PM
johna1's Avatar
17 E220D, 11 E350 CDI(sold), 06 CLS320 CDI (sold), 05 Cadillac DeVille (gone), 04 E320 CDI (sold)
Great to see a good result, and another example of the worth of the board.
