Changing Tire Disaster
Anyway, I changed a lot of tires in my day, so I never resorted to the MB manual, and changed two tires on this car before with no problem. However, after removing lug nuts off this tire, I was not able to take off the tire. I read the manual, and it mentioned having to put in a special lug after taking one nut off (VDOT tow guy mentioned this to me as well). My wife and niece was trying to help and ended up yanking the car off the jack!! Fortunately, the tire was still on, so I jacked it up and successfully removed the tire. But the dumb car falls off the jack again w/o any tires on it!!! Of course, I'm sh-tting my pants now (excuse the language). Fortunately, after additional failed attempts to jack up the car, a VDOT (Virginia Department of Transportation) tow truck pulls up behind me, and gives me a hand. I thank my lucky stars as I probably would have to wait forever if I called up AAA.
Does anyone know whether car would be badly damaged from falling off jack? I bought new tires, and car seem to drive ok, but I'm going to take car to dealer next week. Also, does anyone know where this special lug nut is?
If you couldn't easily remove the wheel, it was probably stuck because of corrosion or road gunk. I'm not going to speculate if something was damaged by the car falling off the jack, since your dealer is going to inspect for damage next week. Personally, I wouldn't wait that long for an inspection.
Any car with alloy wheels should have a coat of antiseize on the wheel's hub to prevent dissimilar metals corrosion between the wheel center and the hub. Reapply at every 6500-mile tire rotation.
You need to review jacking procedures in owner's manual as it shouldn't be so easy to collapse the jack.
You can always kick the bottom of the tire a bit to loosen a stuck wheel.
Or you can loosen but not remove the studs, lower the car back down to ground and rock it a bit to loosen the stuck wheel.
Mine also stuck the first time I rotated tires (common problem). Clean the rust from the center of the wheel/rotar and just put a smear of grease on the circumference. I haven’t had a problem since.
Hope the car didn't get buggered up when it fell off the jack. Good luck.
Better to be safe than sorry.
This is the 3rd time I have used the jack (well, 3rd and 4th since I put a plug in to hold me for a few days and put the tire back on, if the plug does not hold it will be the 5th in the morning) and it always makes me nervous. When up all the way there is precious little surface area and on an even surface a good bump would knock the car of the jack, or at least so it seems. Nice and compact design but dangerous if you needed to change a tire on the side of the road, if I had parked one row up I would have needed to drive the car to a less frost heaved surface
. Anyone know where to get a jack pad that fits the recess the jack head fits into?
I thought that's what knees were for.....
I must have missed something else....
