E-Class (W211) 2003-2009
Dvd Navigation ???
Old Aug 24, 2006 | 12:30 AM
socale320's Avatar
Dvd Navigation ???
I have an 03 e320 with dvd navigation.. how can I make it play actual dvd movies??? thanks for the help!
Old Aug 24, 2006 | 07:49 AM
KosherBenz's Avatar
Its big and Grey!
Read here, you need to get a Euro comand. The US version will not play DVD movies.
https://mbworld.org/forums/e-class-w211/155852-where-did-you-get-your-euro-comand-all-questions-answered.html
Old Aug 24, 2006 | 09:42 AM
jdhoang's Avatar
2021 GLE 450
I have US 2003 E320, and used 3-5-7 trick to allow playing DVD movies. Read following thread:
https://mbworld.org/forums/e-class-w211/87170-3-5-7-confusion-dvd-head-units.html
Brief summary from miguk_saram:
* it's not 3-5-7; it's 5, then 3-7, hold until menu appears;
- change to the appropriate settings
- turn off the command (without switching screens)
- turn off the car, leave off for about 5 minutes
- come back and check to make sure the settings took
* both the keypad and the display need to be set to ECU
* insert the DVD into the single CD slot; you should get some sort of acknowledgement from the unit, whether or not it's able to read the DVD.
* if the settings took and it can't read the DVD, then sorry, you're out of luck; if the settings didn't take, then try again and leave the car off for a longer period of time.
Old Aug 25, 2006 | 08:08 PM
iookpareke's Avatar
Some US comands have DVD drives while some dont. I believe most if not ALL EURO comands have DVD drives.
Old Aug 28, 2006 | 12:10 AM
socale320's Avatar
correction, i have an 04 e320.. is there anything i can do to reprogram my current unit to play dvds??
