Is there a VCS owners manual/instructions ??
My '04 E320 has VCS with a small lever on the RH side of the steering wheel.
(for voice recognition calls I imagine)
Nothing about it in the owner's manual or in the command manual. Whenever they mention vcs, it says "see separate operating instructions."
Dealer says no separate book/instructions. If any of you have one would you please describe it and, if possible, a part # would really help. Thanks
Received 4,440 Likes
'71 Pinto
![rolf](https://mbworld.org/forums/images/smilies/rofl.gif)
Anyway for now here’s a copy of the instructions given for the 06 CLS, operation should be more or less the same.
https://mbworld.org/forums/e-class-w211/125676-liguatronics-appointment-made.html (post #21)
No seperate book/instructions
https://mbworld.org/forums/showthread.php?t=125676 (post #21)
"Voice Control System operation guide". Or are you saying they didn't print one in '04,
even though the OM references it ?
'71 Pinto
Anyway, I just wanted to give you something in writing that you can reference until a 04 owner can give you the reference # from their VCS guide so the dealer can get you one corresponding to your model year. More than likely there are not any changes between model years 04 through 06 however, it would be best that you have the right guide # so the dealer cannot deny you in requesting a copy.
Try a call to MB CAC @ 800-367-6372 this might get you a copy of the guide you’re looking for. Make sure to have your VIN handy.
'06 E500, '99 ML430 and '07 SL65
'71 Pinto
Here you go.
Thanks again for your responses KT....a realy big help ! (I missed the dealer inference)
And thanks sgaar for the pdf.! What would we all do without this forum ?
2015 ML 350
"Voice Control System Operation Guide"
"Order Part No. P-279903A (07/02) SJJN4791A"
In the mean time, whatever application you are in pull the lever & say "Help" the syetem will respond with a list of valid commands for that application. There are no commands for the Navigation unit or Satellite Radio or to enter Satellite mode by voice. You have to push the button.
You can also go into set up & have the list of available comands be displayed on screen whenever you say "help".
If you have the V60 Phone you need not switch into the phone mode to voice dial. Just pull the lever & say "Dial Name" when you are listening to the radio.
You will find the voice recognition is stupendous as long as the windows/roof are closed. Speak to the windshield mirror area.
After reading through the manual, it appears that the only difference is
that my '04 doesn't have the voice intelligent training feature via command.
Thanks Barry, since I bought the car 3 weeks ago I don't know why I was under the impression that
the VCS was strictly for the phone....
probably because I didn't have the manual, and didn't notice that lever.
![Frown](https://mbworld.org/forums/images/smilies/frown.gif)
