Oh Well, I Give Up
They didn't do the DSB for the heat coming out of rear A/C vents, while the front tries to cool off the car. Instead they claimed that they did an Evac & Recharge of the A/C & found a leak in the system. (The A/C was nice and cold so there was no leak).
My 2 keys STILL do not summer open the windows and the roof, except once out of 50 tries... they said the "reprogrammed 1 key for parking aid".
They didnt replace 2 black push fasteners along the black plastic moulding inside the trunk next to the left tail light, even though the RO said they did. I still had 2 holes. I went to the parts department to BUY them & put them in myself. (The parts guy gave them to me)
The Tire pressure monitor display malfunction which was in memory with several codes, was working when I brought the car in after being out for 2 days, twice during the preceding week. Their solution? Replace the metal MB valve stem caps with silver painted black painted caps. The MB caps have been on the car since it was new, the display had not failed until this past week.
I got home, put the car on the driveway, shut it off & got a display message "Close Sunroof!" ..The damn roof was already closed because the A/C had been on.
My 7 Speed transmission still shifts abruptly 1-2 & 2-3, and sometimes has to downshift 2 gears when coming out of a turn because its "in the wrong place" despite parts replacement and numerous program updates...
None of the problems with the car have been resolved. Ever. In almost 3 years of owning the car. I'm still plagued with the same enjoyment robbing electronics bull ****.
I'm disapointed with this $69 thousand dollar car to say the least. I won't buy another. My feelings WILL be indicated on any JD Powers surveys I recieve. Not ranting & raving, but a true indication of the car and its service.
I'm done. I give up.
I have been following your trials/tribulations for some time now.I too have had some recurring problems but obviosuly not your extent. Maybe it's time to call the regional service manager and get them involved.
Hope all works out well.
Best
Jay
I'm also sorry to hear of your ongoing bad luck with this car. I'm really convinced that people who buy highly optioned MBs are asking for trouble -- this is ridiculous as luxury cars are supposed to be highly optioned and all that stuff working.
Guess you're going to look to trade for a car that's built on the other side of the world.
Best wishes and good luck.
Regards,
paul...
So they did change out the SDARS receiver, just like the DTB says, and I STILL HAVE THE PROBLEM??? Thats not the dealerships fault.
Why would they offer me a buyback 3 years later? I wouldn't want to add any money to the deal and STILL end up with an E Class with the ongoing electronics issues. If I'm going to add money, I want something dependable, that gives me pleasure EACH and every time I start it up. I don't want to hold my breath while it "boots up" to see what's not working right on this drive. I don't want to be in the middle of a drive and get a correct or an incorrect error message, or have the A/C blow hot air on the rear seat passengers so hot that it overwhelms the whole car.
I tried. I was patient, I was understanding, I waited my turn, I drove loaners, I drove my own "Airport Car", a '96 Chevy Corsica POS... I played by the rules. Dealer service department managers came & went, SA's came & went... I don't believe that MB has licked all the aggravating problems on this generation E class and that they are putting all their effort into a perfect next generation E class, and trying to get by for the rest of this generation's model run. Even the guys "not having problems", ARE having problems they dismiss as "gremlins" that come and go.
I have no faith in the Brand any more as of this week, or their dedication toward making my 211 a quality automobile. I'll probably get something new in December/January & run like a scalded cat. I really tried. $ 69,000 is A LOT of money to spend on a car, let alone one that tortures me.
[MB]CRS (dealership tech) “There is technical help in the states as well as personnel that comes to the dealerships periodically or when needed.” Just about sums it up. Without MBUSA intervention you can forget resolving these issues to your satisfaction whether by repair or othwerwise.
I understand NO car company can keep every customer. There are no (extremely) hard feelings, I just feel the experience should have been a good one.
Also your patience seems like it was strung out to the end. You should have contacted corperate long ago...
Regards,
paul....
The dealership also claimed they swapped the antenna with the new Satellite kit, but I know they didnt due to the same weathered look of my old black hockey puck style antenna. A new antenna would have been a color matched (Pewter) small ice cube antenna.
All told, I still have every problem I ever had with the car... NONE have ever been resolved. There are not many of them but they are absolutely infuriating, as they all are a finger poke in the eye to the driver. .. and they all recurr randomly.
The basic "car" part of the car is rock solid. The electronicly operated options ALL suck.
(2) Intermittent tire pressure monitor failure should be resolved by changing out the TPC module (left side of trunk, behind rear SAM) to the latest release.
(3) Since the DTB process did not resolve the transmission shifting problems this can be readily addressed by your dealer contacting the Enhanced Diagnostic Assistance Center (EDAC) who may very well approve a new transmission.
(4) Since the DTB process did not resolve the SIRIUS signal failure, once again, this can be readily addressed by your dealer contacting the EDAC.
(5) Close sunroof malfunction, the Battery Control Module (BCM) may need to be reset. I’m thinking under certain conditions communication faults may occur between the BCM and the CAN bus.
(6) Rear A/C intermittently blows warm air in cooling mode, replace the heat exchanger valve and/or Driver side Signal Acquisition Module (SAM) as per DTB.
(7) Easy entry/exit seat moves to incorrect position, replace electronic ignition switch (EIS) as per DTB.
BTW, every so often reset the ECU to wipe out what was learned (for improved performance):
- Turn to the on position (#2)
- Press the gas pedal to the floor and hold for about 5 – 10 seconds
- Turn the key to the off position (do not remove) without removing your foot from the gas pedal
- Do not remove your foot from the gas pedal for at least 2 minutes waiting for the ECU to reset
Bring the vehicle to another dealer, have documentation on hand, speak with the service manager and request that the area MBUSA Service Parts and Operations Manager (SPOM) monitor the process, get your loaner, go home and pour yourself a Glenlivet.
When buying a car I have always taken into consideration the after sales service. We are NOT in the position where we can simply try a different Mercedes dealership, so if I were Barry, I'm afraid it would be goodbye Mercedes and perhaps hello ugly BMW or Audi?? Both ugly looking beasts, but decent dealerships.
Life is far to short to get uptight over this sad ongoing debacle, get rid of the car and hopefully move on, but remember the grass might not be a better quality elsewhere??
Good luck,
John
Blown away is right. I used to say: "Once you drive a Benz, you'll know why there's nothing like it." Heh Heh.
