Can an E500 break the wheels loose?
so I held break with left foot and slammed down on the gas with the right... all the way till I hit the accelerator button at the bottom
and I broke me loose for a little bit, Im wondering if E brake will hold and I tried this? Does our E brake lock up the fronts or the rears?
http://www.ajeepthing.com/burnouts.wmv
I think your technique is wrong. This is what I do. First I press the brake lightly. I then press on the gas with increasing pressure. If the car starts to move forward increase the pressure on the brakes just a bit. Once the car is stabalized, keep on increasing the gas. It should break loose by then.
Think of me as you want, but as you can see, this thread has quite a bit of interest. I drive an E class yes, but it doesnt mean I cant have fun with it...
I am going to try and tweak that methodology and get it to work... this car certainly has enough power to break wheels loose and bake...
Put it into Dyno-mode. Then it'll smoke the tires all-day-long (works on my car anyway).
Ahhhhh, close grasshopper, but not quite.
1. Turn key to ON position (position II).
2. Mash throttle to the floor (5-10 seconds) making sure you hit the kickdown button.
3. Turn key to off position
4. Remove foot from throttle.
5. Keep key inserted for 2 minutes or longer and then start car.
I believe this actually resets the adaptive tranny on the car. I'm sure if I'm wrong, someone will chime in.
And if you want to screw around with dyno mode, here's the link. There's even a how-to video. Not sure if this works on Non-AMG cars but you can give it a shot
https://mbworld.org/forums/showthrea...ight=dyno+mode
LMAO!!! Yes, I was thinking that you'd actually want to drive the car after doing the reset. But, yes, you could definately take the key out after the 2 minute wait and come back later to drive the car.
Had some fun the other night with ESP off and some slightly humid streets.
