E-Class (W211) 2003-2009
Can an E500 break the wheels loose?
Old Oct 18, 2006 | 04:14 AM
  #51
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
Originally Posted by MB AMG
Don't use the E brake. It locks the rear brakes.
I think your technique is wrong. This is what I do. First I press the brake lightly. I then press on the gas with increasing pressure. If the car starts to move forward increase the pressure on the brakes just a bit. Once the car is stabalized, keep on increasing the gas. It should break loose by then.
so it rained today and I used this technique a little... worked like a charm, car barely moved, Ill try it some more when its dry out...
On a side note, the look on people's faces when you pull in to a mall parking lot, turn the ESP off and start doing donuts and figure 8s... PRICELESS
Old Oct 18, 2006 | 10:20 AM
  #52
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
Originally Posted by ATS
Yes, you can not accelerate and brake at the same time in a brake/drive by wire.
If you want your wheels to spin, go buy the worst tires possible.
If you want tire spin go by an AMG. ON second thought go buy an AMG that doesn't have the ECU reflash!
Old Oct 18, 2006 | 02:36 PM
  #53
NVR_L8's Avatar
Corvette
Man that last comment made me laugh hard!
Old Oct 19, 2006 | 10:17 PM
  #54
kshmr0420's Avatar
1987 Mercedes 300 SDL
Don't drop from high revs in neutral down into drive----ever!!!! I tried this last year in my heavy *** Tahoe. Results were not cool. Ended up blowing the pin out the rear diff creating a hole the size of a golf ball, also blew out 1st and 2nd gears in tranny. Tried to limp back home 1 1/2 miles, and the right rear came out with axle still attached, then grinded on the frame to a stop. Please learn from my mistake!!!
Old Oct 20, 2006 | 02:41 AM
  #55
MB AMG's Avatar
2002 E55 AMG
Glad it worked!! Haha on the last comment, I also started doing donuts in the parking lot while there were some learners trying to park.
Old Dec 12, 2006 | 09:01 AM
  #56
W211 Ryda's Avatar
2004 E320
bringing this thread back from the dead! found this clip of a guy doing a burnout.
http://www.youtube.com/watch?v=C5AKCQ56tsM
