Transmission or SBC problem? what the heck!?
1 Post
4 wheeled car.
Ok this is making me mad. 2003 E320. 43k miles on the clock. I drive through a parking lot with my foot off the gas. Give it a tiny bit of gas and it jerks like it's stuck in first gear. It's doing the equivalent of a guy not knowing how to drive a stick, you know, the jerky back and forth motion. Is this linked to the SBC? Or is it a tranny issue? My dealers are weak and keep telling me that all the stuff is good and up to date. I call bs, there is something wrong here. How to fix it?
Mark, you told me about some Valve or something to replace with an updated part. I mentioned it to my dealers but they say they can't do anything that isnt listed in their bulletins or that isn't diagnosticable (ie, it doesnt do it with them- so they cant fix something that isnt wrong) or that it doesn't apply to that particular series of cars. WTF
Somebody help me. I need a bulletin or something to show them that they're dumb and that there is a known issue.
thanks
thanks
Mercedes-Benz
you mean valve body? That probably doesnt apply to a 2003 W211 because it doesnt have the 7spd trans. The dealer still should be able to fix the problem... i say try a different one.
Received 4,440 Likes
'71 Pinto
P-B-27.60/43b MAR06 Torque Converter Clutch rough engagement and/or droning/buzzing. May be caused by a lack of / or inadequate adaptation.
P-B-27.55/50f MAR06 Harsh engagement possibly followed by droning/buzzing noises during acceleration (1200 – 2500 rpm). This may be caused incomplete adaptation of the torque converter, the transmission EGS ECU software, or glycol contamination of the automatic transmission fluid.
P-B-27.00/47d MAY06 Leaking oil in the area of the Electric Connection, replace the plug adapter/electrical connector. Associated Service Campaign 2006020008 applies if your vehicle is within VIN range.
P-B-27.20/78 AUG06 Vehicle jolt at constant speeds or during gentle acceleration when torque converter clutch is applied. After confirming that the concern is no longer reproducible with the torque converter clutch deactivated and it is verified that glycol is not present in the transmission oil, flush the transmission oil.
1 Post
4 wheeled car.
Have your dealer reconfirm the most recent Engine Control Unit (ECU) software is installed in addition to mentioning the following DTBs:
My dad tells me that sometimes when he applies the brakes it jolts forward too, again at low speed.
mike can you recreate the problem on command? tell the tech to get in the car with you and recreate it
Slow speed problem
I too have recently experienced the problem described - but it rarely happens. I have an '03 E320 with 37K miles. I spoke to dealer about it and the service advisor knew exactly what I was trying to describe. He didn't say what needed to be fixed, but asked me to bring the car in for service, which I'll do at the next Service interval. Interesting to know what causes it.
07 SL550; C32 (sold)
1 Post
4 wheeled car.
I'm gonna call Mark Cummins today to ask him what it was that he told me, and see if one of you guys are able to pull me a bulletin on a it b/c w/o it the dealer claims there's nothing they can do, or when I mentioned to them what to do they said "oh yeah we know, it's common" only to return to get my car and get a "Oh yeah it doesnt apply to this year."
bullcrap.
is a German Tank
abrubt. Well a typical case is when he goes uphill on a particular street, not too steep but steep nonetheless. He climbs it at no more than 25mph and then when initiating a left turn, if he just lets off the gas and turns w/o applying brakes, no problem but if braking, the car jolts forward hard to the point where it locks seatbelts! I told this to my dealers many time but they can't replicate it so they don't do jack about it! It's starting to **** me off becasue the warranty will only be there for so long!!
bullcrap.
bullcrap.
2003 E320 Pewter KG
I experienced this since I first got the car two years ago. It is very rare to happen but when it does it is very annoying.
At first they said it may be the MAF sensor. I tested it with a STAR diag but it was working fine. It gave 11 or 13 as i remember.
Then they said it will be the torque clutch converter. I asked the tranny mechanic. He knew about it and changed a few. He said the part costs $1800 if new and only $300 if used. However the used ones doesnt always work and may not solve the problem.
I'll leave it for now but will do the tranny service ( fluid and filter change) soon.
^I also experience this at 76,500 miles on my 2003 E320. Its not annoying enough for me to rush it to the dealer but its still in the back of my head. I was thinking of leaving it be for now, I doubt there are any harmful side effects of this. Its the same as letting the clutch slip when your engaging first with a M/T
i have the same exact problem always happens at slow speeds.. i thought it was the sbc break pumping the breaks.. thats kind of what it feels like and also since the seat belt locks im assuming it would have to be the sbc......
e500 sport
Have you ever had transmission serviced? did your MB service department actually do a glycol test to see if coolant is mixing into transmission fluid? I gad the same thing happen to me 3 years ago and that's what they found. I ended up having to replace transmission, torque converter and radiator with new cooler lines.
1 Post
E320 CDI
i added 100ml of new transmission fluid. The tranny runs more quietly. I guess I didn't add enough fluid last time I did the fluid change. I think I will add 50ml more to see. 722.6 is very sensitive to fluid level.
1 Post
E320 CDI
http://www.theworkshopmercedesbenz.c...ansConcern.pdf
has anyone tried the lock-up re-adaptation? My lock-up is definitely coming in in a wrong time. I really don't know why. When I go down a ramp, it will engage it to have some engine braking. It makes a droning sound. When I press the brake to stop, it will disengage and jerk. The procedures look hard to attain on normal road. Having to keep the car at 50km/h without slowing down is hard.
hi everybody, happy new year! newbie here, im driving 06 e350, i have 55,000 miles on it and im starting to experience that jolting thingy mostly when my transmission is set to sport. anybody has the answer?
