AMG Rim Fit
camry
AMG Rim Fit
Just wondering if any of you guys know if the 18" OEM AMG rims fit on the E 320. I'm in the process of purchasing a set from a 2006 E 55.
car & rim both W211, right? should fit just fine based strictly on wheel specs.
the rest is up to you in terms of selecting properly sized rubber. i grabbed
05 of same from board member and am using them on my 99 W210. had to
purchased 12mm bolts with 14mm ball seats though. your application shouldn't
require new bolts - just your exisiting ones will be fine.
...next is lowering
...next is lowering
1 Post
sold - w211 e320, f250, rx7 race car
And in case you get bored with the E55 wheels like I did, YES the E63 fit as well...
E430 , E500
I think it should fit..e55 has much larger clearance due to bigger caliper...but make sure you get the right bolt pattern and size of bolt 14mm
2015 ML 350
[QUOTE=Jakarta Expat;1909441]These are 18" OEM's that came off of a CLS 55
[QUOTE]
Just out of curiosity...
Near the left rear quarter panel of your car is a big gray box on the wall with pointer guages & colored lights behind some glass doors that sorta looks like a "time machine". What is all that?
BTW... NICE Garage!
[QUOTE]
BTW... NICE Garage!
03 E500, 95 Porsche 993, 93 Mazda RX-7
I have a set of 19" AMG 2 pc. sl wheels at 19x8.5 fronts offsets 30 monuted with 245's and 19x9.5 rears with 275's offsets 31 on my 03 E500 lowered. no rubbing issues or fitament problems.
W211 / E280
[QUOTE=Barry45RPM;1911828][QUOTE=Jakarta Expat;1909441]These are 18" OEM's that came off of a CLS 55
BTW... NICE Garage!
The small meter on the far left is the electricity meter from the Indonesian Electric Company. The big box shows the power coming in to the house on 1 set of gauges and lights and the other set of guages and lights operate when the State electricity goes dead (which happens around once a week) and the Generator I had installed automatically starts up and kicks in. If I moved the car you could see the incoming cables from the genset coming in at the bottom of the box and that would help you.
BTW... NICE Garage!
2004 SL 350 & E class 200K avantgarde
[/QUOTE]
Nice wheels of E63! I consider these wheels instead of E55 wheels. Are these wheel are fit nicely (I know the rim width are wider in E63(8.5J/9J) in regular E class?
[/QUOTE]
