E-Class (W211) 2003-2009
12V / battery line in engine compartment??????????
Old Mar 23, 2007 | 04:14 PM
no_clue's Avatar
.... nothing to brag about, it is a previous model....
Can anyone show me where I can tap a 12V line in the engine compartment, that is directly feed from battery w/out going through fuse/ resistor or ECU?
(E320)
thanks,
Old Mar 23, 2007 | 04:40 PM
raymond g-'s Avatar
99 E320
hey, check the engine compartment. i believe your car and mine (for one)
has terminal points right above the left wheel well...close to the firewall.
the purpose was to allow booster cables w/o having to route under the
rear seat. (presuming your battery is still under the seat).
plastic cap swings open and should have a big "+". ground would be clean and effective chassis ground.
Old Mar 23, 2007 | 04:46 PM
New E350W4's Avatar
'07 E350W4
Hmmmm?
As stated, I thought there are terminals onder the hood but, just looked in the owners manual and it doesn't say BOO about this, only in the trunk. In fact, that's where they refer you when jumping the battery(or someone elses)
Old Mar 23, 2007 | 04:47 PM
no_clue's Avatar
thanks Ray; ( battery in the trunk now )
for your curiosity, I am installing a relay to HID ballast.
I don't want to have the ECU program to "xenon present", just in case, I want my regular bulb back on.
Old Mar 23, 2007 | 05:27 PM
health services's Avatar
The relay may not show enough resistance to the computer and may still set off the code. You may need a resistor in series to the relay.
Old Mar 23, 2007 | 05:40 PM
no_clue's Avatar
Now I am confused even more....
The HID kit I installed works perfectly when engine is NOT on.
When I started the engine, both flickers like crazy!!!!!
I suspect the ECU is NOT providing enough current, hence I try to tap the 12V directly to the ballast.
Old Mar 24, 2007 | 06:09 AM
KosherBenz's Avatar
Its big and Grey!
you need to go to the dealer and acitivate "Xenon present" in their computer.
Old Mar 24, 2007 | 06:42 AM
no_clue's Avatar
I did mentioned that I don't want to have the ECU program to "xenon present", just in case, I want my regular bulb back on.
Old Mar 24, 2007 | 06:48 AM
KosherBenz's Avatar
Its big and Grey!
then just go back to the dealer to have them deactivate it.
Old Mar 24, 2007 | 07:13 AM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
I'm not 100% on this but I believe that the setting will have no effect on using regular bulbs. I believe it is designed to detect low or no current draw.
Old Mar 24, 2007 | 11:57 AM
raymond g-'s Avatar
99 E320
Originally Posted by New E350W4
Hmmmm?
As stated, I thought there are terminals onder the hood but, just looked in the owners manual and it doesn't say BOO about this, only in the trunk.<.....>
ahhhh.....seems now that the under-hood positive terminal was discontinued
after they moved the battery from under-seat.....back into the trunk. so
you're right. no more under the hood access. sorry for the misdirect.
Old Mar 24, 2007 | 12:28 PM
KosherBenz's Avatar
Its big and Grey!
i have a small battery under the air cabin filter.
Old Mar 24, 2007 | 12:35 PM
amdeutsch's Avatar
Administrator
MPG+ ROLFCOPTER
Yup, the E has 2 of them; one small, one big, one front, one back.
Old Mar 24, 2007 | 01:46 PM
raymond g-'s Avatar
99 E320
yeah...i'm getting mixed up and got redirected towards jump starting the car.
so the rear battery should *only* be used for jumpstarting (whereas on my
99 E320, the engine compartment terminal can be used to jump). N_C's
query was simply to tap for power so that's different...and I s'pose, can
consider that front battery.
btw...what does front/smaller battery handle? misc electronics, no doubt?
Old Mar 26, 2007 | 11:12 AM
SAguirre's Avatar
04 E320 4 Matic, 95 Audi S6, 99 Carrera 4 Cabrio, 12 Fiat 500 Sport, 00 BMW R1200C 10, BMW R1200R
If you have the daylight running lights on, then the computer lowers the voltage to the non-xenon lights (H7) so that they last longer. If you have the actual setting changed in the computer this will not happen. This is one of the many reasons why the computer needs to be set to accept the 35W draw of a xenon light instead of the 55W draw of the H7 bulb. Xenon lights are not dimmed if you use the "constant" setting on the daylight running lights. So if you do set a resistor in parallel, and you have daylight running lights on you will still have problems.
Hope this helps a bit more.
Steve
Old Mar 26, 2007 | 05:03 PM
no_clue's Avatar
I believe small front battery is for ECU and remote control?
Also I still don't know where the heck is the 12V terminal in the engine compartment!!!!!
Old Mar 27, 2007 | 12:51 AM
raymond g-'s Avatar
99 E320
i dont think there is one, R. I haven't seen any reference to a POS terminal
under the hood for jump starting in the W211 where the battery is in the trunk.
i searched through quite a number of PDF manuals and it is absent any mention
of this ....versus, say in the W210 manuals with battery under the rear seat.
here are two examples.....
Old Mar 27, 2007 | 01:50 AM
no_clue's Avatar
thanks Ray.....
this is really pissed me off though.
I will NOT let dealer to program my ECU yet.
I will find another way which suggest by fellow member Allen.
(capacitor, here I come!!!!!!!!! )
Old Sep 6, 2013 | 09:06 PM
tlluberes's Avatar
Mercedes E320 2004
I think in Starter you have 12 volts + permanently.I think starter are in Engine compartment
Old Sep 6, 2013 | 09:13 PM
tlluberes's Avatar
Mercedes E320 2004
For my car, i used 12 volts from auxiliary battery in engine for feed relay for my HID.Not Problem. This Red wire came from trunk battery for to be charged.
This front battery is for brake pump.
Not problem. In The regular H7 socket i used regulator canbus. Ebay $ 10.00. Just for avoid warning light in dash.
Old Sep 10, 2013 | 04:34 PM
starbrite's Avatar
2004 E320
Uhmmm....you do realize that this thread is 6 years old, right?
Old Aug 4, 2016 | 11:24 AM
PDX4matic's Avatar
1999 e320 4matic
I don't care how old this thread is, it solved my problem of finding a 12v constant under the hood! Thanks for the help, 3 years or 30 years!
Old Aug 4, 2016 | 07:41 PM
nivram13's Avatar
E240 -2003 E55 AMG -2005
Fuse tap into cig lighter fuse #54 on front SAM switched feed.
