Would a 20x9 20x11 wheel fit the e-class?
BMW M5
I found the perfect set of wheels, only problem is that they are 20x9 and 20x11 in the rear. Is it possible to make them fit? I have the e350
Mercedes benz E500
the 20x9 have no problem in fitting for the front wheels. but the 20x11 it will have a problem. it most probably will rub on the vender. unless you roll the fender. Anyway good luck. i used to put 20*9 and 20x10 and no problem at all..
I'm running.. 19x10.5 in the back.. I have about 1 inch clearance in the back.. no rub.. 11.. you are pushing it to the max.. you might be able to.. put it all depends on the offset of the wheel.. what tires are you going to run.. i'm running. 275/30 series..
