Break squeak - MB says it is normal for MB brakes to squeak
2005 E500 AMG Sport
[QUOTE=avb777;2123289]I agree with avb777. If grease was the solution, then my car wouldn't continue to squeak. MB could grease are brakes all they want and it would only clear things for a few days or so. There's definitely something more.
GL350
[QUOTE=avb777;2123289]I already suggested to use a different compound then mercedes uses ,but you can do whatever you think is good...The problem is the pads are not holding onto the calipers...
GL350
[QUOTE=PlayboyDiddy;2123534]Diddy.i might have used the wrong word .It is not grease ,its a more of a glue that holds the pads in the calipers
2005 E500 AMG Sport
Mercedes E350, E550s on it's way!
MB Brakes often 'glaze' over. As one of the members above me stated, you must get your vehicle up to a high enough speed, and come down hard on the brakes. Taking your vehicle in for service over this will only result in them applying a special anti-squeak compound to your brakes, a oil type substance, which by the way I've had loss of braking power from, and had to immediately return to service to have them remove it. Hard to believe, but when they apply to much, because I HATE the squeaking noise, it can really mess your brakes up.
So again, as the many know on here, Mercedes brakes 'glaze' over at low speeds, it takes a high speed, and enough braking power to heat up, and brittle away the glaze. After doing this, your problems should be behind you.
Many probly oppose this way of doing it, but its the fastest most direct way of dealing with it, and seeing as I've done it every other month when mine start to do this, and after doing so it stopped. Well, you just can't argue with the facts.
#33
#34
2005 E500 AMG Sport
He also stated that glazing is a problem on all vehicles, not just Mercedes. He does not think this is the cause of the squeaking, as my car was doing way before my rotors were glazed, but it could add on to the problem.
I do not know how true it is, as you have had success with this process. Just wanted to share this with everyone.
#35
I've had this issue with a few new MB's in the past and the only long lasting solution was when the dealership replaced the pads and rotors, on one occasion the one of the replacement rotors was causing a squeak and it too had to be replaced. So don't let them tell you it's OK! BTW, my 07 Carrera S's brakes started to make a slow speed squeal at about 1400 miles and is driving me mad! I will have the dealer address the squeak soon.
#36
03 E500 and Corvette
Danged and all this time I was thinking time for coffee.
![Roll Eyes (Sarcastic)](https://mbworld.org/forums/images/smilies/rolleyes.gif)
However for those who do the high speed braking or ("breaking
![EEK!](https://mbworld.org/forums/images/smilies/eek.gif)
#37
BMW FTW
I was told to do the same thing by one of my previous service advisors, but after talking to my friend who is a mechanic at another dealership, I decided not to try it. He stated by doing that, you can very easily warp the rotors and then will need to replace them.
