91 vs. 87 Octane?
I suggest that you stick to 91 octane which is borderline as it is.
Assuming you keep the car for 4 years, the difference in the total cost of this car versus one that was designed to burn Regular, and perform at its best amounts to $1,000.00 . If the best deal you could have gotten for a car of this caliber would have cost you $1,000 more, would you have passed on it?
Think logically. If the car would have cost a thousand dollars more, and the Dealer said they'd let you pay off the $ 1,000 over 4 years, however you wanted, as long as it was paid for in 4 years, that would have been a pretty good deal.
Thats what it is...
Thats what it is...
Barry,
You always make my brain hurt. I hate smart people.
I look at it a more rudamentary fashion. If I fill either one of my cars up with super when they're completely empty, it's roughly 60 bucks. If I fill the same car up with regular, it's roughly 55-57 bucks, maybe, with a difference of about .15 per gallon. For a couple dollars a tank, I'll take the performance, fuel economy and peice of mind.
At 76, I've used regular all my life and don’t plan to change now! And - as you
might suspect - I go long on oil changes.
After millions (I assume) of miles I have never had an engine problem related
(even remotely) to excessive wear or detonation.
I used regular in my 06 DTS and I use regular in my current - and earlier - C6.
I no longer race, so I can’t tell the difference .. although I know that if “maxed
out” there would be some difference.
MANY years ago back in Ohio, when I was very active in tractor pulls, indeed I
DID use the maximun hot fuel available! But my tractor pulls have passed. So,
if my savings is one extra hamburg a month at McDonalds, that’s a good thing!
jimm
On Order: 08 E350 Sport, P2, Black/black,
Parktronic, Voice, Bluetooth, Burl Walnut,
Split rear seat, Rear mud flaps
Personally I can't see why someone would want a "Performance Sport Sedan" and then intentionally hobble it. There will be a trade off in performance.
http://forums.audiworld.com/q7/msgs/14620.phtml
Out of curiosity, what is the comparative octane of gas in Germany?
There's a station near me that sells, or used to anyway, 166 octane fuel at a select pump. I remember it was 2-3X the price of regular gas
Refuel using only unleaded premium grade petrol with a minimum octane number of 95 RON/85 MON conforming to European standard EN 228.
You could otherwise impair engine output or damage the engine.
You will find further information about petrol under “Technical data” in the index.
You will generally find information about the petrol grade on the filling pump. Otherwise, ask the filling station attendant.
If the recommended fuel is not available and only as a temporary measure, you may also use regular unleaded petrol, 91 RON/82.5 MON. This may reduce performance and increase petrol consumption. Avoid driving at full throttle.
In some countries, the available petrol quality may not be sufficient and could cause coking around the inlet valve. In these cases, and in consultation with a Mercedes-Benz Service Centre, the petrol may be mixed with the additive sold and recommended by Mercedes-Benz (part no. A000989254510). You must observe the notes and mixing ratios given on the container.
RON is roughly equal to PON (US) although not always. I don't think fuel in Germany is burdened with additives like ethanol.
There is a Super grade of gasoline in Germany that has a RON of 98.
The manual states that if you can't get Premium, to put in what you need with the highest octane you can find, then switch back to Premium at the soonest interval. (To average the octane.)
We can debate this for ever... so seeing all of the above, put in whatever you want into your car, just like I'm sure is done in the loaner cars.
BTW, I use 93 only in my turbo car and my M car, but the MB seems happy on either.
Regards,
Jerry
Regards,
Jerry
I know for porsche 911 it makes about 11hp difference but even then it is almost impossible to detect via butt dyno. 911 engine is a high strung/compression engine so I doubt if MB looses that much power, may be 5hp.
I assume MB having the 2.6L engine which is almost same as my BMW, it will behave the same.
