Rotors warped AGAIN on 06 E350
Wheel bearing damage can happen after just one nasty encounter with a large pothole and usually the slower the speed the worse the damage.
Have the wheel bearing replaced and the rotor. These are really throw away items and dont cost that much that it would really matter. You are better off with AMG brakes anyhow. That would make your mothers car look really cool.
In any event I hope the dealer was sensible enough to replace both front rotors and pads. You might want to check that.
The SBC issue should be covered under warranty...
something is just not right....our brakes should last longer than what you've experienced.
good luck...
In my experience, warped rotors are often caused by uneven torquing of the log bolts or lug nuts. Whenever I get lazy and do not retorque my wheels, thinking Costco/dealer/tire store must know what they are doing, some time later my rotors have warped.
It has never happened when I torque the bolts myself afterwards. This has happened on my Honda, Porsches, BMW and now the E350.
Torque wrenches are cheap at Harbor Freight. IMHO, it is the evenness of the tightness, not the absolute foot/lbs that is critical to prevent warping, so a 2-5% inaccuracy of a cheap torque wrench is acceptable - certainly a lot better than a torque stick used on an impact wrench.
Cheap insurance, and takes very little time. I torque in 2 steps, 60% and then 100% of the factory spec in an every-other bolt rotation. I disagree with Costco who torques in sequence of 1-2-3-4-5.
