E-Class (W211) 2003-2009
Would removing the model number badge
Old Jun 27, 2007 | 10:20 PM
Piranajoe's Avatar
2003 E500
from the trunk leave any paint marks or scratches?
Old Jun 27, 2007 | 10:55 PM
harpz's Avatar
no it shouldn't if its done properly (i.e. don't yank it off) if anything maybe a little glue residue which will come off
Old Jun 27, 2007 | 10:57 PM
mbuskuhl's Avatar
sold - w211 e320, f250, rx7 race car
Not if you are careful. Use dental floss to separate the emblem from the car, then goof off or other non destructive adhesive remover, finally some good wax. Do not use your fingernails and take your time, be patient.
Old Jun 27, 2007 | 11:53 PM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
dental floss worked like *** for me, it kept breaking... get yourself some hot water... and some fishing line
Warm up the letters by pouring the water on them... then use the fishing line to peel back all the glue behind the letters
Old Jun 28, 2007 | 12:25 AM
lig's Avatar
lig
was '03 E320 - now - '04 S4
Hair Dryer + fishing line worked like magic.
I removed the slight outline left by the letter/numbers with Scratch-X and applied polish.
Voila!
Old Jun 28, 2007 | 12:46 AM
anthon's Avatar
When I removed the badges from my car, I used Goo gone and a few pieces of floss. Took a little bit of work, but got the badges off without a scratch. And i let a professional attached mercedes emblem it require careful mounting with the use of special chemicals so that it can be bonded rigidly to the finish without damaging it. Although i can install it myself with some hardware included on the badge.
Old Jun 28, 2007 | 06:48 PM
Piranajoe's Avatar
2003 E500
I'll give it a shot. Thanks!
Old Jun 28, 2007 | 07:45 PM
ProV1's Avatar
MB, BMW
to hide the scratches you can always stick on a "E55 AMG" badge
Old Jun 28, 2007 | 07:59 PM
Piranajoe's Avatar
2003 E500
I got badge off pretty well. There is however a light film where the E500 badge was. I have waxed it, but it remains. Should I leave it and with future cleaning and waxing it will fade, or should I try something else?
Old Jun 28, 2007 | 10:31 PM
mbuskuhl's Avatar
get some "cleaner wax" at your local auto parts store, that should do the trick.
Old Jun 29, 2007 | 07:44 AM
glojo's Avatar
E-class E300e Estate, Sprinter (stretched limo)
A hair dryer works wonders in heating the bonding. If you get the badge warm enough then dental floss will glide through the bonding.
The hair dryer also works when removing any dealer decals that get placed on the rear window.
Regards
John
Old Jun 29, 2007 | 11:24 AM
Barry45RPM's Avatar
2015 ML 350
VM&P Naptha... AKA Tar Remover, AKA carpet stain remover, will get it off. From Home Depot or Paint Store.
