E-Class (W211) 2003-2009
Audio50 installed - Question
Old Jul 5, 2007 | 03:36 AM
mspaul's Avatar
2018 Macan, 2018 Panamera Turbo S E-Hybrid, 2024 G63
Ok Guys.. Need some experts to answer this.
I installed an audio 50 unit in my 03 w211.. everything was working fine...
But today.. I had a long drive and was playing an mp3 cd.
Some folders/ songs in the cd just don't play.
They play for 1-2 sec and then stop... then after sometime.. plan another 2-3 sec and then stop again.. and this goes on.
Whereas other songs work just fine.
anyone have any suggestions??
FYI: I checked the bit rate for the songs.. but did not fine and pattern Or I would say.. could not conclude anything.
Old Jul 5, 2007 | 04:15 AM
no_clue's Avatar
.... nothing to brag about, it is a previous model....
I am bit confused.
Audio 50 does not have any CD/DVD drive build in.
Do you meant the mp3-capable-6-disc changer or 2004+ command center?
If you installed a new "Audio 50" in your car, have you "re-seat" the #6 fuse in your trunk?
And Reset factory setting in your instrument?
Also, if you have not exceed 192k bit rate, then try to shorten the name of the song.
I notice some LONG name mp3 file have problem playing in my Command properly. (some non-english-name file may also cause the command longer time to recognize as a "music file".)
Old Jul 5, 2007 | 12:48 PM
mspaul's Avatar
Originally Posted by no_clue
I am bit confused.
OH.. Dang... sorry.. its a 2004+ command.
Do I need to reset something?
How would a software know if the song is non-english.
As far as the file has .mp3 extension .. it should work... Am I missing something here?
FYI: Songs that I have problems with are non-english
I'll see if shortening the name works, But there are some songs that have short names but still are not playing (128kbps)
Old Jul 5, 2007 | 01:49 PM
no_clue's Avatar
It is recommend to Star it when you change the new command. But I got lazy and cheap, simply unplug #6 fuse in your trunk for few min. Plug it back in.
Don't turn on the radio yet.
In your commend (instrument), reset to factory setting.
No, it is not about your MB know you are playing non-English songs. It is the name of the song should not be non-English character. (or any language not set from your command (instrument)
Old Jul 5, 2007 | 02:41 PM
mspaul's Avatar
I'll try the reset thing after work today.
and the Non-English part-- the song names are in english font, so that should not be a problem. Right?
The I guess the reset should solve the glitches.
But its strange, I have 4 folders on the mp3 disk and the two folders with english songs work fine.
Only the non-english songs have problems.
Oh, that makes me think if burning non-english song audio cd would work or not. Will give it a try today and let you know. - Thanks!
Old Jul 5, 2007 | 03:02 PM
no_clue's Avatar
Make sure there are all English character, or delete it before burn into your CD or DVD ( view attached photo )
Old Jul 22, 2007 | 04:31 PM
mspaul's Avatar
Thanks no_clue.
I got it working. The problem was with the bitrate.
I encoded the mp3's at 320kbps and everything works!.
Old Jul 22, 2007 | 05:15 PM
murman's Avatar
S213 2020 E450 4Matic CDN Spec 07/19 build
I am bit confused.
What are you talking about??? Of course the Audio 50 has a built-in CD drive!
