Tires - WET LOOK
It doesn't give shinny looks, but it stay deep black w/ constant rain and drive through car wash.
Last time I applied on my tires was on Feb, and I still don't see the need to re-apply them yet.
"I would be cautious using any silcone based tire dressing. They definitely make the tire look so dark and wet but silicone based dressing can be harmful to the tire and your paint. Silicone based tire dressings don't get absorbed by the rubber and just sit on the surface andcan cause browning of the tire. Additionally since it sits on the surface it can be easily slung on to the paint when the vehicle is in motion. This sling can damage the clear coat and make it bubble up. When detailing its easy to tell vehicles that have used too much silicone based dressings. I think silicone based dressings are great for shows but not safe for regular usage. If you do use them buff the wheel dry to minimize sling.
I recommend using water based tire dressing which actually help nourish rubber. The water based dressings like the Poorboy's World Bold n' Bright still give a great shine but without the risks. http://www.detailedimage.com/store/p...roducts_id=145 "
Aceman
http://tireific.com/
Foam applicator, thin coats of Endurance. It's not the most shiny of tire dressings but I like it that way.
Satiny w/ the first layer and then more shine w/ each application.
No issues with slinging.
Poorboy's Bold n' Bright is another good choice. You don't have as much flexibility with it in terms of appearance, and it is almost a pure liquid, so can get a little messy. However, if you want a shinier appearance, this is a good choice.
For the interior (use a different sponge), VRT is awesome. It has SPF 65 in it and is not overly glossy on the dash. It also has an anti-staticizier within it to prevent dust build up. Also, when you get it on the windows when applying on the dash and doors, it wipes right off.
In the end, there is a trade off between using a water based products and silicone products: while silicone lasts longer, it does attract dust and road grime, and as the gent above referred to, is known to have adverse affects on tires (some react moreso than others...Michelin seems to be the worst).
www.adamspolishes.com
www.poorboysworld.com
