E-Class (W211) 2003-2009
New Chrome Key Features
Old Aug 29, 2007 | 12:11 AM
Ehab320's Avatar
2003 E320, 2015 S550 Mag Black
Angry New Chrome Key Features
Hey Guys, first post here. I have a 2003 W211, and the dealer sold it to me with the old key that had a crack in it, so he ordered a new key for me, and it is the new '07 chrome key.
My issue is that with the old key, the pass side mirror tilt on reverse was enabled and works fine, but now with the new key, I can't seem to get that feature!!!
I have read all the posts on that feature and how it was removed by MB for the later year models of my car, but since I have an '03, and I know the feature exists, could it really be that this feature is completely absent from the new keys??
In other words, can I get my new key programmed to enable that feature again?
Thanks.
Old Aug 29, 2007 | 12:18 AM
GusGusZ's Avatar
2005 C230 SS, 2004 E320
on your mirror controls on the driver door make sure that its set to the passenger mirror and it should would then, another words act as if your adjusting the passenger mirror and leave it alone and try putting it in reverse
Old Aug 29, 2007 | 01:12 AM
bigmel's Avatar
2004 E500 4matic
yeap i got fool by that one too. if u dont have passgerside controls pressed in it will not work.
plus your key have nothing to with the parting aide feature.
Old Aug 29, 2007 | 08:20 AM
E500 Benzo's Avatar
2003 E500 Sport, 1995 SL320
also, some of your car's features are key dependent.... therefore you would loose them if you used a different key than you normally would (which may be the case here). if you go into your settings in your MFD (the settings inside the instrument cluster) you can disable the key specific options (which i beleive include among other things include seat and mirror memory positions)
try that and post back with your results... good luck!
Old Aug 29, 2007 | 11:43 AM
PetePap's Avatar
'03 E500 Sport
Hey GUS! What Happened. You Decided To Change The Way You Type?!
HaHaHa!!
PetePap
Old Aug 29, 2007 | 12:16 PM
lasvegas99's Avatar
E500
I just got a crack in one of my keys (outside plastic casing). Did you get just a cover and replaced the internals or did the dealer reprogram a whole new key?
With regards to your issue, I believe you just need to set it through the steering wheel with your new key in. It is under... Settings\convenience Thats how I did it when I switched keys once I got the crack in the other one. btw.. I actually turned it off because I could see better in the normal position and didn't like the limited visibility when they are turned down.
Old Aug 29, 2007 | 06:36 PM
GusGusZ's Avatar
Yeh I Did Actualy Lol.
Old Aug 30, 2007 | 05:50 PM
Ehab320's Avatar
lasvegas99: I actually did get a new key that was programmed by the dealer for my car. As for getting to the settings menu in the steering wheel, can you help me out with that a bit?? When I flip around, I only see the 'reset to mfg settings ..' option, but I don't know how to pull up the settings in the cluster. Thanks.
PetePap: Would you leave GusGus alone!!! It is interesting to know that there is someone who uses the Shift key as much as they use the Space key when they type!!
GusGus: I do press the pass side adjust button when I go into reverse, but it has not worked ...
I will try to figure out the MFD settings for the key-specific options and let you guys know if it worked. I hope it does!
Thanks all for the replies.
Old Aug 30, 2007 | 09:06 PM
GusGusZ's Avatar
Ok Try This Go In The Menu Settings And Scrool Down And Youll See Convience Click That That Youll See The Menu For The Mirror Make Sure Its Set to On , Then Make Sure Your Mirror Control Is Set To The Passanger Mirror And It Should Work You Must Have The Feature Turned Off In The Convience Settings , My Opinion Is That Whole Mirror Thing Is A Joke Unless Your Paralell Parking When Your In Reverse All You See Is The Ground Very Dangerous When Just Back Up Normally Not Paralell Parking Hope It Helps Guss
Old Aug 31, 2007 | 01:01 AM
Ehab320's Avatar
Thanks guys, I found the option on the settings menu, and it worked like a charm!!
GusGus, you can set how far the mirror tilts down so you can see exactly what you need in order not to hit the curb ... I agree that it is dangerour if you're just backing up, but that's why you can turn it off by hitting the drivers side mirror adjust button, right?
Old Aug 31, 2007 | 09:53 AM
GusGusZ's Avatar
Exactly Right I think Its Perfect For The City But A Accident Waiting For Anywhere Else
Old Aug 31, 2007 | 10:46 PM
zergcerebrates's Avatar
w211 E320
The tilting passenger mirror during reverse mode was removed for later E class models??? REALLY?
Old Aug 31, 2007 | 11:42 PM
JDM_SXE-10's Avatar
2003 E500
Yes sir/ma'am.
Old Sep 1, 2007 | 02:58 PM
Dema's Avatar
i535
What about C/S and others? I hope the options was removed for cars with parcking distance control and auto park feature.
