E-Class (W211) 2003-2009
275/30/20 will this rub, what tires shoud i get on my 07 w211 sport
Old Sep 1, 2007 | 11:23 AM
gstatus929's Avatar
2014 E63 S-AMG
Exclamation 275/30/20 will this rub, what tires shoud i get on my 07 w211 sport
hey i have a 2007 e350 sport
im getting 20" wheels
either 20" 8.5" et35 front
and 20" 10" et42 rear
the tire size i was recommended was
245/35/20 front
and
275/30/20
will this setup rub?
if i got 245/35/20 all around on a 8.5" rim will that rub?
Old Sep 1, 2007 | 01:05 PM
gstatus929's Avatar
2014 E63 S-AMG
no drop
Old Sep 1, 2007 | 05:52 PM
Benz-O-Rama's Avatar
Don't know if it'll rub or not but that is not the correct tire size for 20" wheels. If you run those tire sizes, your speedometer will be off becuase the overall diameter will be bigger. For a 20" staggered setup, you will want to run 245/30/20 and 275/25/20 to ensure that your speedometer will not be off.
Check tirerack.com for correct wheels and tire sizes for your car.
Old Sep 1, 2007 | 06:35 PM
gstatus929's Avatar
2014 E63 S-AMG
thanks for the response but i dont car about my speedometer, i care about having at least some rubber, 245 30 20 and 275 25 20 is barlly safe to drive on
Old Sep 2, 2007 | 01:29 AM
Then maybe you should consider 19's or 18's. Good luck with running an incorrect diameter setup.
Old Sep 2, 2007 | 02:38 AM
PlayboyDiddy's Avatar
2005 E500 AMG Sport
245/35/20 front
and
275/30/20
I have a 285/30/20 on a 20" 10.5 inch wheel and get a little rubbing. Nothing major. My car is lowered about an inch and a 1/2. Depending on how much you want to lower your car, You can go with either a 25 or 30 series tires.
Old Sep 2, 2007 | 12:58 PM
gstatus929's Avatar
2014 E63 S-AMG
stock hieght, im not gonna lower it yet maybe in a year or so.
so will this setup work on stock hieght
i heard it would
Old Sep 2, 2007 | 03:02 PM
LB Bnz's Avatar
07 E350, 03 Lexus ES300, 04 CLK 320 (gone)
245/35/20 front
and
275/30/20
I have the same set up on my 07 sport...no issues with rubbing or speedo...
the 35 & 30 series are enough tire to give you a smooth ride... That was my main concern...I have 2 boys (10yrs old & 10months old) with a full car, I have had no problems with the ride quality....also, you don't need to lower your car since you have the sport...unless you want the 'slammed look' then maybe 1.2" drop all 'round will do the trick...you gotta show some pix when you got it all dialed in....
Old Sep 2, 2007 | 03:29 PM
Although you may not have rubbing issues, I can tell you that your speedo is definately off. The total rolling diameter has changed therefore your speedometer has no choice but to be incorrect.
Here is a great website that will do the calculations for you.
http://www.miata.net/garage/tirecalc.html
Here is a screenshot of the data for your particular application. Notice when your speedo says 60mph, your actually traveling 62.5. Or a 4.2% error. Obviously, as speed increases so will the delta.
275/30/20 will this rub, what tires shoud i get on my 07 w211 sport-tiresizeerror.jpg
Old Sep 2, 2007 | 07:40 PM
Vik888's Avatar
2008 E550, 2012 GL450, 2014 GLK350, 2015 S550, 2020 GLC350e
Would the odometer be off as well?
Old Sep 3, 2007 | 03:09 AM
2005 E500 AMG Sport
i heard it would
I don't see why it won't work. I think even if you lower your vehicle, rubbing shouldn't be an issue and if so, very minimal.
Old Sep 10, 2007 | 03:17 AM
2008e350's Avatar
2008 Mercedes Benz E 350
245/35/20 front
and
275/30/20
Go with 285 30 20 in the rear. I have it set up that way on a 20x10 in the rear. I have not dropped the car yet though.
Old Sep 10, 2007 | 09:14 PM
JDM_SXE-10's Avatar
2003 E500
Are you sure about this? I contacted Luke from Tire Rack and he told me to run 235/30/20 with 275/25/20 in order to maintain the correct diameters. I did the calculation also, and it does appear to have the closest diameters to run those sizes. Originally, I wanted to run 245/30/20 but the overall diameter of that setup will be greater than the 275/25/20s that I'm using in the rear.
