E-Class (W211) 2003-2009
Bluetooth Text Messages (SMS)
Old Sep 12, 2007 | 12:48 PM
ATS's Avatar
ATS
2004 E500 / 2001 C240
Has anyone had any luck getting the TEXT message (SMS) features to work with any bluetooth phone?
Old Sep 12, 2007 | 03:42 PM
jmorgis's Avatar
2013 SLK
i believe from reading the manual that came with the puck, its not supported.
Old Sep 12, 2007 | 03:43 PM
ATS's Avatar
ATS
True but unsupported phones are not supposed to work too..
Old Sep 12, 2007 | 04:20 PM
Diesel Benz's Avatar
SMS works with the Euro BT SAP puck, but that is hardly of any interest to you.
Old Sep 12, 2007 | 04:44 PM
bigmel's Avatar
2004 E500 4matic
the sap puck has a sim slot too?
Old Oct 3, 2007 | 11:25 AM
jallison12's Avatar
2004 E500 Wagon 4Matic
I have an SMS soft key??
I just had a BT puck (I think the one with no tail, as I already had a cradle in the car) installed by Auto Addiction in Lindenhurst NY. I have a Motorola Q and a BB 8700g, and both phones pair no problem with the puck.
I did notice though that on the Tel display I now have a soft key (the top, right key) that now says SMS. I haven't tried it yet, but it is there. I will give it a try tonight and see what happens. I'll let you guys know tomorrow.
jim
Old Oct 3, 2007 | 11:39 AM
Barry45RPM's Avatar
2015 ML 350
SMS stands for "Short Message Service"... what the wirless folks call TXT MSG, or text messages. Although I don't get TXT's sent to my cradled phone ever, I guess if someone does send you a TXT Msg you press that softkey to read it on the Comand Screen.
Old Oct 3, 2007 | 12:20 PM
Yes it has, the SAP puck can be used like a normal cell phone in the cradle.
Old Oct 4, 2007 | 02:10 AM
Vik888's Avatar
2008 E550, 2012 GL450, 2014 GLK350, 2015 S550, 2020 GLC350e
You cannot read SMS's that are already in your phone. You can only use the SMS soft key to read new incoming msgs.
I have a V3 RAZR w/ the BT cradle.
Old Oct 4, 2007 | 02:45 AM
georgedaman's Avatar
GL350
Can you do that on your comand?
Old Oct 4, 2007 | 05:19 AM
pinebaron's Avatar
07 E320 Bluetec
Though I have not tried, I believe you can also send SMS via command.
Old Oct 4, 2007 | 01:48 PM
ATS's Avatar
ATS
Can someone try..
Old Oct 4, 2007 | 01:55 PM
Originally Posted by ATS
Can someone try..
I know you are waiting for info from US car owners but SMS reading and writing works fine with the Euro BT puck, through COMAND. Comand does not allow writing while driving but it does allow reading while driving.
Technically the BT HF puck is different, the SAP device looks for the car more like a phone in the cradle. But I often read and write SMS messages from my phone, using my laptop over the BT connection. Should be possible for COMAND then too (not sure if this is using some proprietary interfaces as I am using a PC application from the phone manufacturer).
Old Oct 4, 2007 | 02:05 PM
jmorgis's Avatar
2013 SLK
My SMS button is always grayed out, i have a blackberry. My phonebook works fine. I recall reading the BT w/ tail does not do SMS.
John
Old Oct 4, 2007 | 02:26 PM
GL350
Did anyone in this thread or forum ever received or sent an SMS through the comand?
Old Oct 4, 2007 | 06:27 PM
jallison12's Avatar
I'm gonna try tonight
Should be leaving work soon, so I'll give it a try in the carpark before I start the long crawl home
Old Oct 5, 2007 | 10:08 AM
jallison12's Avatar
FYI
Q=Motorola Q Verizon
BB = Blackberry 8700g T-Mobile
1. I paired the Q, and sent a text message to it from the BB. Nothing showed on the COMAND screen. All this time the SMS button was greyed out.
2. I then paired the BB, and sent it a txt message from the Q. Same result.
So, I couldn't read any txt messages on COMAND, nor any alert that a message had been recieved by the phone. And no way to type and send a txt message from COMAND.
I have the US COMAND unit.
Oh, well...
Old Oct 5, 2007 | 10:17 AM
I guess the US system still supports SMS messages through COMAND if the phone is used with a cradle?
Old Oct 5, 2007 | 01:40 PM
GL350
Originally Posted by jallison12
FYI
Oh, well...
Do you know if the SMS is enabled for sure on your system?..through the STAR ofcourse.
As far as the Euro Comand goes MB couldn't even enable this option saying that the teleaid system is not compatable with the EU comand...(thats why the phonebook doesn't dowload either in the EC mode)
Old Oct 5, 2007 | 01:48 PM
jallison12's Avatar
Not Sure
I have only had the car for a few weeks. It was pre-owned and don't have a full vehicle history. I am figuring that as the SMS option is on COMAND, even though greyed out, the potential is there. If could be a STAR change is needed to enable the function?
Old Oct 5, 2007 | 01:50 PM
jallison12's Avatar
Or, as DieselBenz says, it only works if an actual phone is in the cradle?
Anyone selling an old MB-V60?
Old Oct 5, 2007 | 04:31 PM
GL350
Yes it is in the STAR menu.I tried mine with a V600 (or something similar) original MB phone...also had the SMS actually lit up on the comand,with the SMS enabled with the STAR..still didn't work.
Thats when i was told ,it is because of the EU/teleaid compatibility.
Old Oct 5, 2007 | 09:23 PM
pinebaron's Avatar
07 E320 Bluetec
SMS is greyed out if there are no messages. Try sending an SMS from another phone and then check it.
