E-Class (W211) 2003-2009
Yellow ESP® warning light flashing
Old Sep 12, 2007 | 03:05 PM
seahonu's Avatar
2015 GLK 250 BT
Wonder if you folks frequently see that yellow ESP® warning light flashing? I've noticed that it flashes pretty often when I'm taking a corner pretty aggressively but not with any wheelspin, ie. no sound of tires squealling. I'm wondering whether it due to my tire sizes since upgrading to 18" staggered. Fronts are 245/40/18 and rears are 275/35/18, originally from a CLS. The recommended rears are 265/35/18 so just slightly different rolling distance, 1%.
Would that be enough to trigger that yellow ESP® warning light to flash because the rears versus fronts are tracking differently? And that I would need to swap down to 265/35/18 so that the system doesn't flash so much?
Old Sep 12, 2007 | 04:53 PM
bigmel's Avatar
2004 E500 4matic
My Esp warning light triggers when i take a corner hard too. As for a tire squealing I think the esp system is working the way it should, bc its compensating for wheel slip before it happen.
Old Sep 13, 2007 | 09:23 AM
emilner's Avatar
S560
My car does the same, I find it is a little too quick to trigger. I have to go to the dealer to fix my ESP. Almost everytime I drive the car now after 20 minutes of driving the ESP inoperative warning come on the info screen. In order to reset it I have to stop and shut the car off. I think MB has Microsoft handle their software, good thing the car does not ask me to close all windows then shut down and restart...
Old Sep 13, 2007 | 11:00 AM
starbrite's Avatar
2004 E320
Originally Posted by emilner
..... I think MB has Microsoft handle their software, good thing the car does not ask me to close all windows then shut down and restart...
Old Sep 13, 2007 | 11:16 AM
lasvegas99's Avatar
E500
On the W212 I heard on the steering wheel there is a Cntrl - Alt - Delete
Old Sep 13, 2007 | 12:21 PM
Vik888's Avatar
2008 E550, 2012 GL450, 2014 GLK350, 2015 S550, 2020 GLC350e
Old Sep 13, 2007 | 12:53 PM
vettdvr's Avatar
03 E500 and Corvette
That's the way it is suppose to work. However you can fix that problem.. Back off the throttle and ease around the turns. When the ESP is on you are pushing the limits of your traction. It will save you 99% of the time, buy you can't deny physics and limitations. Push too hard and it WILL SKID OUT.
Jim
Old Sep 13, 2007 | 05:44 PM
AndrewAZ's Avatar
BMW FTW
Flashing just about everyday.. I think its a little oversensitive and overreacts especially in dry conditions.
Old Sep 13, 2007 | 06:11 PM
tpliquid's Avatar
too poor now
my dads 550 just started to say esp inoperatable. he dont take to dealer he just drive it
Old Sep 13, 2007 | 06:22 PM
bigmel's Avatar
2004 E500 4matic
Other day when I was in the middle of using the nav to direct me to an address. I shutdown the car in the middle of it saying the next turn. When start the car a few hours later, the nav screen showed "Nav device unavailable" and the dash was stuck showing the last street I was driving on. I had to shutdown the car and waited 5 mins. when the car started it back up the first thing it did was finish saying the last direct before I shut it off the last time it worked.
Old Sep 14, 2007 | 09:01 AM
emilner's Avatar
S560
I had that once, on labor day weekend. I tried everything including the Microsoft fix (shuting the car off/restarting it), The next morning it was fine.
I'm renaming my car the Gremlin....
Old Sep 14, 2007 | 12:09 PM
tpliquid's Avatar
too poor now
i drove the car today and the esp inoperable came on. the suspension became stiff. anyone have stiff suspension when esp inoperable message displays on the cluster?? i could feel everything on the road even on softest setting setting.
Old Sep 14, 2007 | 02:03 PM
Blk04cobra1's Avatar
2002 S430, 2004 Cobra, 2004 Tahoe
The light is doing it's job...it's letting you know that TC is being implemented...try turning it off and taking the same corner again...might make it a bit more fun!!!!
Old Sep 14, 2007 | 02:26 PM
bltserv's Avatar
2005 SL55, 2000 CL500
That little yellow triangle light is working just fine. I notice mine when
I start getting it a little hot in a corner or off the line.
Turn it off and have some fun. Just dont wrap it around a pole.
