E-Class (W211) 2003-2009
Visit Workshop Message
Old Sep 23, 2007 | 08:14 PM
GeorgeThompson's Avatar
Silver 2004 E500 4Matic
Hey Guys,
I got the dreade Visit Workshop message today. The "Raising Vehicle" image is displayed along with the visit workshop message. Is this an indication of the problem or just a default image? Anybody else get this message? The Airmatic seems to be fine. I can still switch between comfort and sport. Its still about 6500 miles to my next scheduled service and I'm hoping what ever the problem is it could wait a few months.
Old Sep 23, 2007 | 08:27 PM
konigstiger's Avatar
'71 Pinto
Originally Posted by GeorgeThompson
Hey Guys,
More than likely a sender unit (measures vertical oscillations of the chassis - influences dampening functions) needs replacing. Since you received the “visit workshop” warning, they should have no problem diagnosing it because a fault code has been stored. I would not wait and bring it as soon as possible.
Old Sep 24, 2007 | 02:42 AM
georgedaman's Avatar
GL350
Wish it was that easy//Took about 5 visit to the MB by the time I/ one of our poster found a service bulletin on a pinched wire around the back wheel .
In the mean time i got parts changed and reprogrammed in every visit .
Old Sep 24, 2007 | 06:55 AM
Firenza's Avatar
E350
Same thing happened to my car three months ago and I had the COMPRESSOR UNIT replaced and the problem was solved. The original Compressor Unit was getting weaker and weaker which caused it to need more time to pump the air to the structs when they needed it. Unfortunately two weeks ago, the malfunction appeared again. After serveral inspection taken from dealer, they soon found out that there was a leaking linear close to the compressor unit. So they replaced the part (MA211 327 02 45/LEITUNG) and another part (MA000 327 03 69/CONNECTOR) and the problem was solved again. Now everything is fine and hope this will help you someway.
Old Sep 24, 2007 | 07:52 AM
That sounds pretty expensive. Were the repairs over $1000?
Old Sep 24, 2007 | 08:14 AM
vettdvr's Avatar
03 E500 and Corvette
I call the dealer the $1000 store.. So you can decide if it is expensive, everytime I go in it cost me about $1000
Old Sep 24, 2007 | 08:50 AM
Firenza's Avatar
E350
The cost for the Compressor Unit including replacement charges was less than USD:550. (I believe in the U.S. the labour cost must be very expensive).
Old Sep 24, 2007 | 10:34 AM
jallison12's Avatar
2004 E500 Wagon 4Matic
Your telling us!!
Old Sep 25, 2007 | 01:08 PM
sang55's Avatar
K3 05 E55 sold, 09 GL550
Hey Guys,
Probably you have bad rear or front axle sensors that also happened to my car . Did you low your car ?
Old Sep 25, 2007 | 02:21 PM
I haven't done anything to it. The message hasn't returned. Only got it the one day.
