E-Class (W211) 2003-2009
My Heater will not blow hot air
Old Oct 25, 2007 | 03:16 PM
eagle67's Avatar
Back about 3 months ago,live in HOT Alabama,the rear air would blow hot hot air at random but only for a few minutes. Did this for about a month, then it quit doing it.Now today I tried to cut heat on to warm up the car, nothing but freezing cold air comes out. It is a 2003 E-500 with 60,000 miles. Anyone have similar problems? or suggestions
Old Oct 25, 2007 | 03:49 PM
konigstiger's Avatar
'71 Pinto
As per DTB P-B-83.20/72, the changeover valve (part # A2118320584) - #30 in diagram needs to be replaced. Valve is located in the engine compartment, beneath the plastic trim below the windshield on driver’s side.
Old Oct 25, 2007 | 04:14 PM
eagle67's Avatar
Thanks so much
Old Nov 7, 2007 | 12:06 PM
eagle67's Avatar
Air and Heat both work great now. Thanks again.
Old Nov 7, 2007 | 01:33 PM
JDM_SXE-10's Avatar
2003 E500
Did the dealer replace the part for you at no charge?
Old Nov 7, 2007 | 02:12 PM
JDM_SXE-10's Avatar
2003 E500
When issues occur that warrant replacement of parts based on DTBs, do dealerships fix them free of charge even if the vehicles are out of warranty?
Old Nov 7, 2007 | 02:46 PM
'71 Pinto
Only recalls and service campaigns carryover past warranty expiration without question. However, a case can be made to MBUSA by way of the dealership with service management support if the DTB specifically mentions a revised part number to correct malfunction caused by defect.
This DTB does not mention a revised valve but MBUSA EPC (electronic Parts Catalog) shows the recommended part A2118320084 was replaced by A2118320584. Therefore, it is safe to assume the new valve is somehow improved. On this basis, you can request a no cost goodwill repair referencing the DTB, new part number, and depending how far past warranty expiration you are dealership cooperation in presenting your request to MBUSA.
Old Dec 22, 2013 | 04:15 PM
Zippo1937's Avatar
Mercedes E329 / 4 drs
does anyone have instructions for R/R og the heater valve for a '05 E320 Mercedes?
Old Dec 22, 2013 | 04:21 PM
'71 Pinto
Sticky above https://mbworld.org/forums/e-class-w...rol-valve.html
Old Nov 16, 2014 | 01:52 PM
Derek Rodrigues's Avatar
2004 E320
What would be the next solution if this replacement didn't work?
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
