SBC accumulator replacement
i have problems with a W211 with SBC ! after serious checking i found that the SBC Accumulator (some call it reservoir) is faulty.... so is it advice to change the Accumulator only or THE WHOLE SBC HYDRAULIC UNIT ???
thanks !
Just had 2 issues with my 2003 M/B E500, SBC system.
1st..CODE--c249f, and the description is "fault code shows that operating time of hydraulic unit is exceeded."
O.k....well I am in Guam, I have 100% of my service records and brake servicing...No M/B dealer or service center within 3000 miles.
M/B unexpectedly will not ship my car to Hawaii to the nearest M/B dealer at no cost to me to replace my SBC unit...LoL
I am able to get a new (slightly used unit) (20% expected cost) and have my unit replaced. Good to go.
2nd--Sorry don't remember the code...Get the White Brake Visit Service center message..Oh great SBC crapped out..Nope, Accumulator bad- -Replace.
So it turns out my slightly used SBC unit had a high pressure accumulator with a ready to fail check valve in it. It should be holding 150 BAR, and mine only "accumulates" 70 BAR. per my STAR diag testing.
So I have a new accumulator on order, should be in this week. I will power down the SBC via my STAR laptop, bleed the system and "simply" unthread the old accumulator and replace it.
Any tips????
SBC expired at 115,000 miles
Accumulator at 10,000 miles on the previous SBC
I just flushed and filled my brake system with ATE 706302 Original Super Blue Racing DOT 4 Brake Fluid. If anyone has ANY tips on the brake system High pressure accumulator replacement and things to expect...I would greatly appreciate it.
Changing the accumulator will be your best 2nd choice. I do understand your limitations in Guam after being in Okinawa.
Ran through purging sequence, system bleed, pre-tensioning and testing.
System back to 100%, accumulator / resevior can be easily replaced as long as you have a Star system available.
You need to use the DAS unit or Xentry system in order to bleed the system down to be able to replace the accumulator. A simple replacement , the dealer will charge you around ~$1500 to replace it.
Good luck.
Good luck.
Cost of the SBC pressure reservoir, or "accumulator," was US$740.25 from the dealership. Total cost for the replacement job at the dealer was almost US$1400, which included replacing the SBC supply line with an updated version. The updated suction supply line (US$134) was supposed to make the SBC quiet...didn't really do much IMO.
