E-Class (W211) 2003-2009
does anyone have the schematic for non-airmatic suspension?
Old Nov 16, 2007 | 10:36 PM
dannieboiz's Avatar
08' S550, 04' E320 4matic, 03' Acura TL-S 6 speed, 1968 Vespa P150
Was browsing around and found this little drawing, I'm about to replace my stock struts tomorrow with some bilstein HD and H&R.
https://mbworld.org/forums/attachmen...1&d=1193687655
Old Nov 17, 2007 | 03:01 AM
W Cole's Avatar
makes your daughter horny
Theres one of the front floating around on the forums, ill try to find it for you. Do you have any specific questions? I'd be more than happy to answer them for you.
For the front I made a special socket (ground it down) and held onto it with a vice grips in order to get the top hat off.
On the rear you're going to have to take the star headed bolt off where the A-arm meets the sub frame. I didnt realize this at first and it caused me a lot of headache.
Old Nov 17, 2007 | 03:05 AM
dannieboiz's Avatar
I installed the H&R the last time myself but did replace the stock struts. But now shocks are shot so I have to replace it.. Since the new struts only come as tube and it seems like the front perch on the bilstein are adjustable I want to make sure I put the old perch on correctly.
I also forgot the exact layout, of how things are under there. Just want to have the schematic just in case.
Mine is a 4matic but I'm using struts and springs from 2wd
Old Nov 18, 2007 | 03:03 PM
tashakes's Avatar
2020 GLE350
The image you have is for airmatic shocks. Use these (Part 1)
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old Nov 18, 2007 | 03:04 PM
tashakes's Avatar
2020 GLE350
Part 2
File Type: pdf
File Type: pdf
File Type: pdf
Old Nov 19, 2007 | 01:26 AM
dannieboiz's Avatar
wow, that's awesome, thanks Tashakes. Where do you guys find these diagrams? I need to get me one of those.
Old Nov 19, 2007 | 01:52 AM
tashakes's Avatar
2020 GLE350
I have an older WIS (2005), and print to Distiller to create the PDF's. You're welcome, put them to good use.
Old Nov 19, 2007 | 08:39 AM
Diesel Benz's Avatar
WIS from 2005? Sounds like a pirated version? I'm no MB police but I'd suggest being a bit careful when distributing MB copyrighted material.
Old Nov 19, 2007 | 10:33 AM
dannieboiz's Avatar
Did you really have to say that outloud?
