E-Class (W211) 2003-2009
wheel locked...... car won't start......help
Old Nov 22, 2007 | 06:24 PM
gstatus929's Avatar
2014 E63 S-AMG
hey guys..... so iparked my car and shut it off with my wheel turned right all the way..... when I went to start it the key wouldn't go...... I figured my wheel was locked so I turned the wheel while turning the key.....no luck. I made sure the cars in park and pressed the brake and forced the wheel....still no luck.............i called roadside and the tech told me to tow it on monday.......... I'm screwed.....any suggestions? I have keyless go but that olso wouldn't budge.... any suggestions... I tried a diffrent key. I tried force and failed
Old Nov 23, 2007 | 01:44 PM
gstatus929's Avatar
2014 E63 S-AMG
please help
Old Nov 23, 2007 | 06:07 PM
SPIKES's Avatar
2019 S63 COUPE
try disconnecting the battery for about 10 min.......maybe that will help.
Old Nov 24, 2007 | 03:45 AM
Diesel Benz's Avatar
Was not clear to me if the batter was flat?
Old Nov 24, 2007 | 10:59 AM
gstatus929's Avatar
2014 E63 S-AMG
the car works but wheel wont release, what does the battery have to do with it
Old Nov 24, 2007 | 01:46 PM
Nothing with the battery if it runs but just the wheel does not turn. Thought the key would not turn either.
The steering lock is electronically controlled, could it be just a wire or has the electronic steering detent system failed?
Actually I'm still not sure from your posts if the key really turned? It could be EIS related if it doesn't.
Old Nov 24, 2007 | 03:12 PM
gstatus929's Avatar
2014 E63 S-AMG
key does not turn . car clicks like it read the key but wont turn
Old Nov 24, 2007 | 05:48 PM
SPIKES's Avatar
2019 S63 COUPE
you asked for "help please"......good luck
Old Nov 25, 2007 | 09:39 AM
OK, then it is not the electronically controlled steering wheel lock but the drive authorisation. Have you tried your second key? If both keys are inoperable, then it sounds like EIS, error codes would have to be read and if something is broken, it would be in practice a dealer fix.
Old Nov 25, 2007 | 12:44 PM
211E350Black's Avatar
08 CLK350
