E-Class (W211) 2003-2009
What do you guys think about this
Old Dec 2, 2007 | 03:53 PM
b_rashed's Avatar
2007 S550 (S65 Package)
http://cgi.ebay.com/ebaymotors/ws/eB...TODAY.m238.lVI
is this going to work or as my cousin said i might even lose some power. any body ever get this before or what.
Old Dec 2, 2007 | 05:54 PM
Untertürkheim's Avatar
I would not touch those.
Old Dec 2, 2007 | 06:16 PM
User110's Avatar
2003 Cl 500
bro, if you know someone good with pipe bending, you can make one your self for less then half the cost and a better filter.
do it and dyno it
ALi
Old Dec 2, 2007 | 07:11 PM
csumt76's Avatar
LS7 powered Corvette
save your money...
Old Dec 2, 2007 | 07:37 PM
User110's Avatar
2003 Cl 500
how about someone actually say WHY save your money?
ALi
Old Dec 2, 2007 | 11:52 PM
b_rashed's Avatar
do it and dyno it
ALi
thats what rashed told me to do. i just wanted to really see if someone did buy it and try it.
Old Dec 3, 2007 | 12:33 AM
noyu's Avatar
17 E43, 18 GLE400
ALi
I could be wrong but I will my best to answer your question
Here's what I've been told: The engine might benefit if you can supply more air (more air + burn more fuel= more horsepower) however more important is the quality of the air (cold fresh air draw from outside not from the engine compartment).
The reason being is cold air is denser and contain more oxygen with all things being equal the same engine should produce more horsepower if the air it sucking in is colder so if you install one of those short ram intake in theory the engine looks like it will breath better due to less restriction on the cone filter vs the stock air box.
However, consider what the engine sucking in is all the warm (may be hot) air from inside the engine compartment so I would consider that a no no.
Also, from what I've learn longer intake runner produce more torque and shorter ones rev faster but in day to day driving how often we rev our car close to redline all day long?
Here is an article I found on the web about air temperature vs horsepower http://wahiduddin.net/calc/cf.htm
Old Dec 3, 2007 | 12:47 AM
tashakes's Avatar
2020 GLE350
^^^ +1
When I had my A4 Turbo, I read somewhere that every 100 degrees that you lower the intake temperature, you gain 10 HP (or something to that end) that is why intercoolers are important on turbocharged cars.
The ultimate goal should be feeding MORE COLD air, and with these, all you would be feeding is MORE HOT air, since the OEM intakes suck air from in front of the radiator, therefore killing any additional air being fed.
Cheers
Old Dec 3, 2007 | 12:59 AM
noyu's Avatar
17 E43, 18 GLE400
Originally Posted by tashakes
^^^ +1
Cheers
Thanks for supporting my saying!
Also I agrees on the intercooler is a must for all turbo (or any force feed engine) because cooler air reduces pre-ignition thus you can run higher boost (always admire those E55s passing me couldn't resist our forcefeeded cousin)
Old Dec 3, 2007 | 12:46 PM
b_rashed's Avatar
thanks guys. my cousin explained all of this to me but i wanted to see if anyone has used them before but thanks though for ur guys' support.
Old Dec 3, 2007 | 01:02 PM
MJ50's Avatar
Super Moderator
bone stock E55 AMG
too ricey for german car...
wonder if oem kevlar intake will fit...
if not, u can always do custom CF instead...
Old Dec 3, 2007 | 04:33 PM
noyu's Avatar
17 E43, 18 GLE400
Yeah, that will be nice................a custom carbon fiber intake leads to the front and draw fresh air......
Old Dec 4, 2007 | 08:46 PM
brabus2ner's Avatar
Mercedes benz E500
my cousin have a carbon fiber intake host on his c230, and it seems that the car has more power and responds. but you also need to change the air filter. too. but i believe changing the air filter is good enough
