Audio Issue - 2006 E350 with Premium HK L7 system
My wife's car, 2006 E350 w/ premium HK sound, seems to be having an audio problem -- and I can't really put my finger on it. Let me explain...........
When we first got the car, the audio was amazing. solid bass, strong dynamic range, and the Logic 7 sound would envelope you, solid sound from all speakers.
Now, I have just noticed, the sound is extremely flat and shallow, and it seems nearly all is from the front center speaker. I moved balance L and R, as well as the fader F and B -- there is sound coming from side and rear speakers. But, when balance and fader are centered, the front center speaker seems to have just to much emphasis. Also, the bass seems to be weak.
In fact, I delivered the car to the dealer today for a transfer case issue, got a 2007 C280 loaner, and the std audio seems to have more depth and dynamic range than my E350.
What could it be?? amp issue? crossover issue? sub issue?
I am going to call the dealer first thing in the morning and ask them to check it out -- but I believe their response will be, can't find a problem.
I appreciate any advice you can provide!
Ken
I very rarely drive the car, and have just picked up on this concern.
There are 3 "sound" selections - standard (stereo), voice, and L7. While I don't know much about voice (never selected it), could the software be screwed up? for example, locked on voice (mono and center focused) as compered to L7? In other words, could this be a software issue?
Thk!
The reason I ask is when fiddling around with the controls, and fade to rear sound only seems to come out of the lower part of the doors. I know I can look, but it just occured to me and I'm not in the car. Do they not put speakers becasue of the rea sunshade?
Mine also sound dull and lifeless. A few days of fiddling with the sound controls and it got better-I also got used to it.
Ken
when set in Standard, the front center speaker (above Command) plays as much as when set in L7. I thought standard was Stereo, would play through the door speakers, and not play thru the frt center.
Should standard play through the front center speaker?
Thks!
1 - Audio Gateway
2 - One center speaker
3 - Four dome tweeters
4 - Four wide-band transducers
5 - Two surround speakers
6 - Subwoofer
7 - Head unit
8 - CD changer
9 - Antenna amplifier
10 - Microphone
Have the dealer check the audio gateway (AGW) software. They may need to update the AGW Sahara version or AGW software.
1 - Audio Gateway
6 - Subwoofer
7 - Head unit
8 - CD changer
10 - Microphone
Ken
I have the same exact issue, just noticed it a week ago. I did STFF already, no avail. Anybody here with the same problem with their HK L7?
