I just purchased a MB V60i cell phone (CDMA) which intergrates perfectly into the car's system.
I have not activated it yet (Verizon is the provider) and while searching the forums came across this post re activation procedure erasing the MB software : Click here
Has anyone else experienced this ( pressing *228) when trying to activate a used cell phone? I find it incredible that this can happen, but obviously did to cyclrder. Anyone else do this successfully and or unsuccessfully ?
The V60i is not 911-capable, so Verizon will not activate it. The V60s is 911-capable.Originally Posted by starbrite
I just purchased a MB V60i cell phone (CDMA) which intergrates perfectly into the car's system.I have not activated it yet (Verizon is the provider) and while searching the forums came across this post re activation procedure erasing the MB software : Click here
I called Verizon w/the Dec # before I purchased it and they stated that it most definitely could be activated.
Quote:
OK. That's not the information I got, but I hope it works out for you.Originally Posted by starbrite
I called Verizon w/the Dec # before I purchased it and they stated that it most definitely copuld be activated.
Well, ast it turns out I mis interpreted cyclryder's post. I thought by "update" he was talking about the activation process. It's, in fact, a software update for the PRL (Preferred Roaming List). So I can see that it may screw up the MB software.
Obviously, I won't be doing this update !
228 option 2 (update PRL) should be safe. It is 228 option 1 that could wipe out you MB firmware.
How did you get Verizon to agree to activate a non-911 CDMA phone? Is this being treated as an ESN swap on an existing account?
Interestingly, Verizon dose not require existing/used phones to be E911 compliant, only that they be CDMA compatible w/their network.
In fact, if you check their website, they offer a Blackberry that is not compliant.
Apparently, if you read their FAQ, E911 compliancy is a "work in progress".
Pressing *228 OPTION 2 only updates the roaming capability, and Verizon says it should be done Monthly while in your home area. (The '04 had a V60)Originally Posted by starbrite
ExploreCurrently Active Users (1)
