SuperUnleaded Gas
SuperUnleaded Gas
ok,
My car is a 2004 E320. It says Premium Unleaded only. does that mean Super Unleaded ONly? Can I use the regular gas in it?
what damage might result from using regular gas? Any body use regular and not have problems???
thnx
thnx
03 Eclass, 03 BMW 06 Porsche Cayman S, 03 Harley Davidson "bored & stroked"
Last time i read the owners-manual, it stated that regular gas could be used if premium was not available, but to avoid full throttle accelerarion and to fill-up with premium ASAP...
But it is available. They mean if you are running low and the only gas around is regular. You would also be expected to buy as little as you can get away with, and fill it with premium as soon as possible to raise the octane level of whats in the tank.
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
I do not disagree with any advice here. These cars are expensive to operate and maintain. $6.00 / quart oil, tires at $600 set and up, premium gasoline, $50windshield wipers, the list goes on. I run 93 octane gasoline because it exceeds the factory recommended fuel. I don't think that was arbitrary. I will bet that you could use 89 octane fuel if you are willing to:
1. Reduce throttle demand to 50% of available power , less if pinging occurs
2. Minimize vehicle gross weight
3. Avoid high engine temperatures.
I do not agree that the motor will automatically disentigrate.
The knock sensors will retard the timing as much as the ECU will allow.
The available power will be reduced and the mileage should decrease as well.
I cannot back up those claims with personal M-B experience but I have with other vehicles. The choice is yours. Personally, I believe you can dumb the car down with inferior parts, lubricants and accessories till one has to wonder why it was chosen over a cheaper model. No one here bought the thing because it was a bargain. Give it a chance to perform as it was intended. They do get under your skin.
2008 Black Out C350 Saks Edition / 87 VW GTI
Its true that Colorado has lower octane available for the regular (85) and mid-grade (87), but from my experience premium is generally 91 here. Has to do with the higher altitude, cooler and less dense air.
