E-Class (W211) 2003-2009
Will an E55 Airbox fit on my E500
Old Feb 20, 2008 | 08:02 AM
captrivers's Avatar
03 E500 Sport, 03 Eddie Bauer Explorer, 06 Pro Street Chopper
I was advised to use an E55 airbox on my 03 E500. Does anyone know if this will fit?
Old Feb 20, 2008 | 04:37 PM
NCE500's Avatar
2007 E63, 2006 C55
RE: E500 Airbox
Having owned an E500 for almost 3 years, my experience was that the airbox, with the dual inlets and total area of the dual air filters would flow more air than the M113 engine needs.
You might want to consider a pair of Green air filters to negate any filter restriction; I changed my filters annually and mine always rans at it's best when they were newly replaced.
Old Feb 20, 2008 | 07:28 PM
captrivers's Avatar
Thanks, I installed Green filters today. I'm considering an aftermarket airbox and was told to try the 55 box. I'll wait to find an aftermarket box then.
Old Feb 21, 2008 | 05:13 PM
Abboushi's Avatar
911's and beyond
i just replied to the perf. thread. Yes it will 55 airbox will bolt-on w/o mods..
gettin mine on Mon. hopefully will post up if theres a diff.
Old Feb 22, 2008 | 01:56 PM
dacollector's Avatar
13 E350 , 12 BMW 328i
what is and or where can i get green filters?
Old Feb 22, 2008 | 02:28 PM
captrivers's Avatar
collector, do a search there's a number of places to purchase them from. Green Filters allows more air flow than stock while continuing to supply superb filtration. As with any prelubed filter, do not over lubricate.
FORUM, I have another question. Will a C55 box work on my 500?
Old Feb 22, 2008 | 10:16 PM
Abboushi's Avatar
911's and beyond
I dont think it will, It doesnt not look the same as the e55/sl55/cl55 the tubes routing and size look smaller? maybe im wrong but just from pics it doesnt look like it will
C55 engine/airbox
e55 eng/airbox
e500 eng/airbox
Old Feb 23, 2008 | 06:00 PM
captrivers's Avatar
Let me know how the 55 box works for ya.
Old Feb 23, 2008 | 06:14 PM
Abboushi's Avatar
911's and beyond
I tried My uncles SL500 airbox it fits 100% perfect. So it should work.
Old Feb 26, 2008 | 04:30 AM
Abboushi's Avatar
911's and beyond
UPDATE: the 55 airbox is NOT bolt-on.. the air port on the 500's are flat and the 55's are angled, it is very possible to work just have to re bracket the splitter downward is all (I Think?) I will be messing with this thing for the next couple days..
Old Feb 26, 2008 | 04:45 AM
ohlord's Avatar
Leave it alone
the air box flows what the engine needs.
No green filter or k/n will outflow the stock filters that cost 32 bucks for the pair,and you install a new set at every oil change.
Proof of the oem setup flowing all the air it needs:the engine does not run out of power at it's governed limit.
Old Feb 26, 2008 | 09:03 AM
captrivers's Avatar
O-lord, eliminating the governed limit is the modus operandi. That being said, you are correct that this engine is set-up to perform at it's peak with the factories set-up.
I hope you don't believe this.
Abb, keep me updated. I was informed the 55 box will work. I'd like to see one to compare it's airflow capability to my stock box.
Old Feb 28, 2008 | 10:45 PM
Abboushi's Avatar
911's and beyond
OK verdict is, It Will work but you really have to Rig it.. I cut the OEM brackets off and rebracket them so they can fit but the hoses are twisted so i have to get some New hoses of some sort. the bump stops fit so the airbox doesnt move, It is hooked up now I have felt a minor diff. but I think the ECU needs at least 1 day to kick in the more air.. but i will have to check the 1/4 if it made any diff at all. will post some pics of install.
Old Mar 1, 2008 | 03:53 PM
Abboushi's Avatar
911's and beyond
ok, so with the stock airbox best time 13.88 no plastic tabs,KNs,Thermotec.
AMG Airbox stock filters,no tabs,no thermotec 13.83. but I def think i can do better runs I hear the exhaust has a little more rumble now (i may be crazy)!
but the tubes are still the issue, 2 angles not consistently flowing def causing some drag in flow. I need to either A. find new Silicon tubing B. heat up the old 1 and see what happens.
Old Mar 1, 2008 | 08:13 PM
captrivers's Avatar
Abb, great work. But, you do know your 1/4 mile runs are affected by temp, humidity, etc. 5 one hundreds of a second is an improvement. But, is it worth it? Can we use our air filters in that airbox?
I'm contemplating on an aftermarket box. Who else besides RennTech makes one for our model?
BTW, I got my ECU back yestarday. Now it definitely has loads of low-end. I'll give it a couple of hundred miles and If I can't get used to the Sprint Booster. I'll probably sell it.
Old Mar 1, 2008 | 09:29 PM
Abboushi's Avatar
911's and beyond
tell u the truth its not really worth it. but it was cold last nite apx 40degrees. i will have to check on the fitment of the KNs in the AMG box. so u did get the SB huh..! I told you it seems real jumpy lol.. neway I will post pics and more feedback after a little more miles and runs.!
