E-Class (W211) 2003-2009
hid install from hell
Old Feb 25, 2008 | 09:21 PM
gikser's Avatar
Angry hid install from hell
ok so i have been through the sticky forwards and backwards so please dont tell me to search!! im working on my new used 2004 e500 wagon with factory xenons,Im trying to install hids in my foglights,Im using oem audi hella boxes,i have tried the capacitors recommended i have also tried a 50w resistor and still the lamp warning goes on and the foglights start to flash on and off every 30 secondsthis is driving me insane as i am an audi tech and havent been able to figure this out. by the way i bench tested the hids and they work flawless on a 12v jumper box.
Old Feb 25, 2008 | 10:55 PM
lkchris's Avatar
'10 CL550, '12 GL550
HID in foglights?
You're joking, right?
What are Fog Lamps Really For?
Old Feb 25, 2008 | 10:59 PM
Vader55's Avatar
AMG E55, Stage 1, Strait Pipe from Primary Cats
Thats wierd, the resistor should be taking care of this issue, seems that you are still drawing to much power causing the flicker. hmmm.
Old Feb 26, 2008 | 12:52 PM
gikser's Avatar
Angry
ANYONE PLEASE HELP,IM TRYING TO STAY AWAY FROM RESISTORS ID LIKE TO USE CAPACITORS BUT WHERE AM I GOING WRONG????272-1020 IS THE RADIO SHACK PART NUMBER USED JUST LIKE IN THE STICKY BUT IT STILL DOESNT WORK.
Old Feb 26, 2008 | 01:11 PM
ZedStyle's Avatar
Youngtimer
Originally Posted by lkchris
HID in foglights?
not everyone in the world lives in a place where they need fog lights for adverse weather conditions or to improve visibility. never in my whole life have i ever said 'hmmm... i wish i had fog lights right now'. so if they're on the car, may as well make your car look nicer, as long as you don't aim them in a way that will blind other drivers.
Old Feb 26, 2008 | 01:24 PM
tanktube67's Avatar
2008 Black Out C350 Saks Edition / 87 VW GTI
Like a fellow member said
Didn't you get the memo?
Old Feb 26, 2008 | 02:43 PM
murman's Avatar
S213 2020 E450 4Matic CDN Spec 07/19 build
edited
What part of "Xenon or HID bulbs are inherently unsuitable for use in fog lamps", kindly given to you in the attachment, do you not understand?
Old Feb 27, 2008 | 09:22 AM
vettdvr's Avatar
03 E500 and Corvette
This statement is confusing as I don't know your circuit. The resistor in series with load becomes a voltage divider and current limit device. The resistor in parallel lowers the overall restance which results in higher current/wattage. The capacitor in series will pass the current and voltage if it is AC and block DC. When used across the load it becomes a high/low filter and dampens out the oscillations in voltage.
So to say you prefer using a capacitor vs resistor is confusing as I don't know the application. If you have a circuit diaghram it might be helpful to see what you have. Otherwise just from the written description it sounds like you have overload causing a circuit breaker to trip, IF this is the case you have too much current and resistance in series with the load will drop the current. This resistor will also have to be sized in wattage to prevent burnout and it will get hot. Wire wound resistors usually work better in this application. So if you want more help you will have to provide the schematics or find someone who has made the same installation and previously solved the problem. I would like to help more but just don't have enough information.
Old Feb 27, 2008 | 09:46 AM
Yacht Master's Avatar
E-ZGO 53hp., 1999 E 430 sport, 2004 E 55, 2008 Tahoe LTZ on 24"s
Stop. take your HID kit and return it, get your money back.
Only one after market HID kit works and that comes from James at Creative he is a sponsor here. Mine work great.
https://mbworld.org/forums/showthrea...reative+lights
Old Feb 29, 2008 | 12:48 AM
jagata's Avatar
S6 LP640 E500
I think the caps in the sticky are too small, i used larger ones and works fine. I will get in my office in the morning and look at the specs and edit this post.
Old Feb 29, 2008 | 12:50 PM
gikser's Avatar
thanks for your help but i finally figured it out for some reason it would work with the hella ballasts so i put some ebay ones and it works great go figure
