Need Help I changed my own brakes
2003 E320
I recently changed my own front and rear brake pads everything when good but know Im getting some noise coming from the front calipper's. When I step on the brake pedal it sounds as if the brake piston has a little room and it makes a clicking noise. I took the tires off and checked the calippers and the piston is still fully in how do I make the piston align its self so there the piston is not fully pressed in.
makes your daughter horny
2003 E320
reply
No the car brakes well but there is a sound when you press the brake as if there was a small gap between the brake pad and the clipper piston. I took them off and then the piston is fully pressed in.
sounds like one of your pistons froze. doesnt this happen when the piston doesnt go in straight but rather at an angle? have you tried getting it to come out at all? sounds like its just stuck, maybe try putting it back in, or in even more? maybe that will straighten it out, see if it comes out this time.
