E-Class (W211) 2003-2009
hids-resitors
Old Apr 1, 2008 | 03:08 PM
CrimeDoesPay's Avatar
2004 e320
hids-resitors
ok i know this has been coverd i search but did not find a forsure answer
i know that you have to install resistors when putting hids
i used 100ohm 10 watt resistors for my plate light and parking light what size resistors do i need to install hids and why do some ppl use capacitors instead in resistors and if i just take my car to the dealer and have them put it to hid present will this save me the head ache
Old Apr 1, 2008 | 05:05 PM
W Cole's Avatar
makes your daughter horny
The ballasts you have now should draw the correct current as to not trigger a fault. You should not have to install any resistors or have the dealer set xenon to present.
Someone with more knowledge could probably explain thisa lot better, but the aftermarket ballasts we install don't draw a steady stream of electricity - the capacitors are used to smooth this out. Some people have been able to get away without using the capacitors. Personally, I had to use them and they solved all of my problems.
Old Apr 2, 2008 | 02:49 PM
2004 e320
do not have ballasts i am going to be installin and hid kit
Old Apr 3, 2008 | 10:46 AM
2004 e320
so many ppl here yet no one has an answer
Old Apr 3, 2008 | 12:46 PM
2004 e320
come on ppl 100 views and only 1 person has steped up to the plate
Old Apr 3, 2008 | 04:27 PM
W Cole's Avatar
You have ballasts, all HID kits have ballsts including the OEM.
Old Apr 3, 2008 | 04:29 PM
W Cole's Avatar
Install them according the instructions found here: https://mbworld.org/forums/e-class-w211/188825-hid-fog-lights-headlight-install-guide-211-e-series-may-work-other-series-models.html
Id try it without the capacitors first, some have had success.
Old Apr 4, 2008 | 03:38 AM
2004 e320
do not have any hids on car aftermarket or oem i thought u were soposed to install resistors all the shops i ask at they say they use resistors
Old Apr 4, 2008 | 09:05 PM
W Cole's Avatar
Not neccessary. There are several ways to do it. I guess you could install relays and use resistors. But why the added complication?
Old Apr 5, 2008 | 01:41 PM
2004 e320
so basically keep it simple and use the capacitors like inthe stickey
